I already explained why it wasn't, i even thanked you for posting it...I'm sorry that the links I posted were not enough to help along the way. For anything more, I'd have to spend a lot of time actually trying to reproduce your issue, and then further troubleshooting, and tech support isn't something I do outside of work.
Despite the rest of that post blaming the user for not correctly provisioning all the way down, and saying anyone over-provisiong servers, especially in production, is a total hack. It means you are not catering for the adverse effects, and just 'hoping' it goes okay.(After realising asking for advise here was a waste of time i did a lot more research and had already come across nohang but it's little more than a more effective OOM killer, ungracefully killing programs should never be acceptable, but thanks for the link, i guess).
Yea and it's the same result i got after spending a week investigating things for myself after realising that one of the people who replied simply refused to accept that it wasn't to do with VMs, another refused to accept that it was a problem whatsoever and another claims that they...First search on DDG for "how to check if hugepages are used in linux": https://access.redhat.com/solutions/320303
Haven't had their OS run out of resource and lock up in a very long time so probably doesn't have the experience to know what to suggest.use a mixture of Windows, Linux and MacOS in normal desktop use and with the type of work I do I can't say that I've had my OS run out of resource and lock up in a very long time; but I'm also not running resource starved systems. Conversely in the server space I've managed many resource starved Windows servers and once they run out of physical memory and fill up their page file because of a bad app, guess what - they become completely unresponsive. Running out of memory is always going to lead to a bad time, whatever you're using.
I've already told you how to replicate it, open a console > type 'echo {1..1000000000}' and wait for it to be ungracefully killed.On that note, I'm not trying to be facetious or say you aren't having problems, but since I've been using Linux from day one (when it was first announced on usenet), through today both at work and at home, I've never hit such issues.
Yes, I see OOM, but it's because applications or systems are incorrectly provisioned. No, I never over-provision VMs. This does not mean you (or others) do not have a problem, but it's one I have never experienced and the link I posted to the github repo is where I personally would start if I had to fix something. Is that suitable for 'average' users ? I have no idea, but there's a reason my wife and daughter use Macs.
Like i said before simply closing applications is far from ideal, heck it's only just about a step up from crashing the kernel. There are better ways, as I've learnt over the last couple of weeks, to deal with OOM situations.
Yea i wonder why so many people have issues with 'the community'.You obviously - like many - have issues with 'the community', but that's like having issues with 'anonymous' or 'society'. Perhaps ask the maintainers of the VM software, or the distro you use, or the kernel maintainers, as they are the people who know this 'inside out'. The 'community' is just random people, most of whom (especially arch users) who have learned for themselves through trial and error, with some assistance online, but then trying and failing a lot, and that's likely why you get the responses that you do. Again, I'm sorry if this isn't what you're looking for, but it's how things are.
I sincerely wish you the best of luck trying to solve your problem - most of us have been through many similar in our journey - and hope you find a solution you are happy with.
I'm out.
