Panasonic ub820 vs ub9000
30 Nov 2016
Hi all,
I currently have Panasonic UB820 (used for 4k and standard blu rays) on a 83 inch LG OLED. Running 5.1.2 through a Denon amp AVC X3800H.
Would I notice any benefit from upgrading to the UB9000. From my reading, it's mostly build quality and silent operation that I would benefit from? Would I get an improvement to visuals and/or sound?
Thanks all
Man of Honour
29 May 2010
Cheshire
You'd be better off putting the money into calibration, or buying the Spears & Munsil 4K disc and setting up the TV with the 820. Much bigger impact than the minor difference between the two players, especially on an uncalibrated TV.
16 Jan 2003
Nottingham
To be fair I only got the UB9000 because it looks far better, far better build quality and figured with it likely being the last of the physical media players I decided to splash out for it.
1 Nov 2002
Sussex
Absolutely zero improvement IMO other than having a bigger heavier box under the screen. Is it really that much quieter, I doubt it.
6 Sep 2016
If it was couple of hundred quid more ok but it's like three times the price. Granted the 820 is bit plasticity compared to my old oppo but tech moves forward not worth spending money on products that go obsolete
11 Jan 2016
Surrey
Hi all,
Thanks all
Hard to believe it gets noticeably better than the ub820 tbh
10 Apr 2004
Weston-Super-Mare
I also have an UB820, the UB9000 also has a HDR picture pre-set for projectors, which will be of no interest to you.
The remote control is better on the UB9000. You can purchase a replacement remote from the rain forest people which looks like the UB9000 and is backlight.
Other then that as already mentioned it has better audio DAC's and connections.
Man of Honour
29 May 2010
Cheshire
Thanks - what would you recommend?
There are two things to look at. The first, ideally you want a stereo amp that can behave live a power amp when used in surround mode in concert with the surround amp. To flesh that out a bit, one upgrade for home cinema amp owners is to add external power amps for the key channels. The centre and the stereo front channels are the main beneficiaries. However, although that shifts some of the heavy lifting duties away from the surround amp/receiver, it still leaves all the audio sources going through the AV amp's pre-amp section. That might not be the best when it comes to analogue sources and some digital sources too.
The solution is to add an integrated stereo amp which does two roles. On its own, it keeps stereo sources clear of the AV receiver's pre-amp section, so when listening to pure 2-channel music there's no AV gear in the signal path. In AV use, the amp provides power for the front channel stereo speakers. However, unlike a power amp, a normal stereo amp has all the source signals going via its own volume control. This means to maintain a proper channel balance in AV use, the stereo amp needs to be set back to XdB volume level, whatever 'X' happened to be when the AV system was set up. That might simply be a certain point on the stereo amp's volume dial. The alternative is getting a stereo amp with bypass mode. This means that there's a certain input or mode that sends the AV receiver front channel signal directly to the stereo amp's power amp section at a fixed level. In bypass mode then the stereo amp acts just like a regular power amp. All the volume control is done via the AV receiver.
Someone put together a list of older stereo amps with bypass mode. I can't vouch for the accuracy, but at least it gives you a starting point for new or used amps. If you were seriously considering the UB9000 at a grand less what you'd claw back on the 820 then we could estimate a budget of £750. That would get you some really nice amps if you were looking at secondhand. Check out the list here.
The other thing to consider is the power of any stereo amp. Denon AV receivers are pretty potent, but a stereo amp with a toroidal transformer and hefty capacitors doesn't need to match the Denon watt for watt to keep up. Good stereo amps do tend to be strong performers when it comes to sustained power output. I'd stay north of 60W on any premium stereo amps. For mainstream Japanese brands such as Denon, Yamaha, and Pioneer, you might want to hedge your bets with 80+ Watts.
OP
30 Nov 2016
Hi all,
Apologies for the delay, been a busy time at work.
Doesn't sound like an update on the BD player is worth it (sticking with UB820)
Thanks @lucid
Budget wise circa £1,000 flexibility on this. More focus on value for money. So if spending more, gets me worthwhile uplift i can. Happy to look at second hand, new obviously attractive but if I can get better bang for buck.
I pretty much exclusively use it for watching films. Would I notice a big difference?
