Office Connection
19 Mar 2005
Rutland
Hi.
I'm hoping some of you gurus can help.
We have two offices that i want to connect so they can easily connect into the site and use Sage.
HQ - Wireless 500gb connection (Peplink Router with OpenVPN) - Thinking of adding an additional fibre link as we now have access to this type of connection.
Site 1 - XLN Fibre (Basic Router) Patchy service
What I wanted to do was find a way to get a solution that has a 5G fall over for Site 1 and a OpenVPN connection to the Peplink.
I'm also open to hardware firewall/vpn connections.
I know some stuff but this higher level gets a bit confusing and my TL;DR brain wont allow me to get too involved.
18 Oct 2002
Nordschleife
Hi.
Have a think about UniFi and their SD-WAN/Site Magic, https://ui.com/uk/en/cloud-gateways
13 Jul 2005
Norfolk, South Scotland
For a proper commercial environment I would struggle to recommend the Ultra. The UXG is probably more where you want to be. And did you see the U-LTE-Pro automated fail-over?
It’s extremely simple to configure (no configuration really) and it just works. Yes, it’s 4G rather than 5G but if you have decent signal it’s quick enough for an emergency fail-over.
Caporegime
18 Oct 2002
This is the sort of task that Meraki appliances excel at, especially if you are not very clued up on the technicalities of what you're doing
OP
19 Mar 2005
Rutland
Are there any benefits that i would see as a layman to the Cisco kit that make the licences worthwhile?
Looking at the Cisco Meraki GX50, assuming I need two of these at HQ and Site 1
Our Peplink has two WAN ports for the wireless so use that to provide WAN to the Meraki and then plug LAN into our Netgear Switch.
13 Jul 2005
I don’t know the GX50 - that’s one of their new UniFi-like GO units where you pay up front for the hardware and then annually for the security updates. Where I’ve seen Meraki before it was MX65, MX68 and MX75 depending on size and complexity of the operation and they effectively give you the units for free or very little and you pay £500-ish per year for the Security and SD WAN option licence. And I believe thats £500 per unit so if you had 2, then £1000 per year in licences. It might sound like a lot but the sites where we installed that gear were very straightforward and the support from the Meraki team is exceptional. Don’t know how to configure your firewall? No problem, they just dial in and sort it out. Access point gone offline? Here’s an advanced RMA unit, no charge.
As for Unifi, If you get 2 UniFi UXGs or UDM Pro SE and set up VPN Magic between them, that should “just work” and then 4G/5G failover on WAN2.
OP
19 Mar 2005
Rutland
Thanks so much for the advice.
Assuming i can mix and match the Unifi devices between sites, also i can connect the UDM-Pro via 10gbe to my Netgear switch?
I want to open another site in 18 months so Unifi looks like the cost friendly solution.
