2nd hand hard drives - what to check?
1 Mar 2004
Warwickshire
I'm considering buying some 2nd hand HDD in the 14+TB range for media storage.
Not the Chinese located or the OEM/datacenter 'refurbished' resellers you get on eBay/Amazon, but where a private seller has pictured the serial number/manufacture date & SMART stats.
If the serial number checks out as having say 2+ years warranty remaining on the Seagate UK checker, & it passes a full disk scan with HDTune on arrival, i'm thinking it should be a fairly low risk/low cost way to buy?
Has anyone done this, & particularly is there any SMART stats that are key to telling how good a drive might be/how it was used?
I know to watch for the reallocated/pending/uncorrected sectors as an indicator for a failing drive, but assuming all are 0, i'm not too sure about how to read/interpret all the other stats, or what the 'ideal' drive stats might look like.
Don
19 May 2012
Spalding, Lincolnshire
Nothing wrong with most of the IT Brokers on ebay - a lot of themn even offer warranty/replacement and drives from servers/datacentres have likely been treated arguably better than most home users.
The only stats that you can really glean anything from are power on hours and power on cycles.
A drive with high power on cycles has likely been used in a home system that's regularly shut down and powered back on. Power on is one of the more stressful events for a drive.
Power on hours is also obviously a sign of how much the drive has been used - so comparing that with the manufacture date, can give you an idea of how much use it's seen - e.g. whether it's been run continuously since it was installed (e.g. in conjunction with a low power on cycles figure), or whether it's had an easier life as a cold spare, or occasionally powered up backup device.
OP
1 Mar 2004
Warwickshire
Yeah maybe. My simple logic is that for the same price they charge, you can get a used retail drive that still has 2-3 years manufacture warranty, which I assume will always be better than a 3rd party eBay random seller warranty.
Also TBH I don't really like the grubby way they seem to do business.
I mean if you go on Amazon and type in '16TB hard drive' it looks like out of the top 10 results, 4-5 are refurbished drives from 3rd party sellers, and some are not even labelled refurbished/used. The Seagate one for £195 is even titled 'buy new' with 200+ sales in past month - you only see that they are refurbs/have 0 OEM warranty by reading the 1 star customer ratings.
Don
19 May 2012
One of the Brokers that I originally found on ebay, I buy direct with these days - and they offer a 3 year warranty. Any issues and they'll next day me a replacement drive even before I've sent the old one back.
We tend to buy a lot of used hard drives / ssds for HP Servers from them - we can normally get 2 or 3 drives for the price HP would charge for 1, whilst still having decent support.
I'd avoid Amazon, as the 3rd parties on there you have very little protection - at least with Ebay there's a bit more in place. Better to have a look on Ebay - find one of the big resellers and then see if they have a separate web site or contact details, if buying in bulk especially you can normally negotiate a better deal by buying direct and avoiding ebay/paypal's cuts. The reputable brokers should also be listed on Company House, so you can double check their details etc on there.
28 May 2010
Leeds
I bought a second hand 8TB HGST Helium HD from CEX (they had a few of them in the shop). I saw on the label it was 4 years old so I was humming and harring about it, but it was very cheap. When I got it home and ran crystal disk, the powered on time was 30 minutes and it had only been turned on twice! I guess it had been originally bought by a company for RAID and not used. Two years later despite heavy daily use it's still running fine
19 Dec 2006
UK
Think they cover drives with a 24 month warranty too, how difficult they'll be when a claim is needed I've no idea.
