Call Of Duty: Modern Warfare / Warzone (Battlenet ID's in OP)
18 Oct 2002
Cambridge
What settings, resolution and GPU are you using? I get drops to 70fps sometimes in Warzone on rebirth island using a 3090 Ti, 3440 x 1440 max settings, doft and blur off. Unless you playing in PS2 graphics mode like the pure sweats you wont hit 165 fps constantly.
I have my fps capped at 97 (100hz Gsync 3440 x 1440 monitor)
Got a 1440p monitor and a 3070ti. I only play multiplayer. Pretty sure I have it on relatively high settings but will double check when i fire it up next.
6 May 2009
1440p ultrawide or 1440p (2560 x 1440) ?
1440p ultrawide is pushing another 1,267,200 pixels (4,953,600 vs 3,686,400)
1 Oct 2011
Cambs
I believe 3 is the new one.
I’ve seen on YouTube people seem to be playing DMZ again? Has this got updates? I thought they dropped support for it? (Which was a shame, really enjoyed that game mode)
19 Aug 2005
Beds, UK
That’s a really good shout, I feel like some games gave done this before too.
Activision would never allow it, they need everyone to see the skins to get FOMO so they buy them.
This!
The thing that bugs me the most is the stupid animations when you get killed. i dont what that in my game, would like to be able to switch it off.
6 May 2009
Whats the best image quality setting, I had it on DLAA but there's DLSS setting which ive enabled and DLSS plus or something that needed me to turn on GPU scheduling in graphics settings. I did that and rebooted.
Or I use CAS or one of the AMD settings.
Im on a 3090 Ti wioth 5800X3D, running 3440 x 1440, settings all maxed expect DOF and blur. Sometimes i'll get drops to 70fps and have even see 55fps on rebirth island. I always used to get 97fps solid when it was Warzone 2 on the older engine and that was with a 2080 Ti or maybe even a 1080 Ti. Slowly the fps seems to dip lower and lower. Im sure Activision work with Nvidia and AMD to sell 4090s :D - oooh, spend another £1500 and get 15fps more... but then you need to upgrade again in a couple years.
27 Jan 2020
West Sussex
If you want more performance just drop everything to low and enable Fidelity CAS to sharpen the game.
DLAA reduces performance (not as much TAA) - but if you're exclusively after performance then you need to lower your settings significantly from having everything maxed out.
19 Apr 2012
Have a look online, there are some good YouTube videos that go through each setting (with benchmarks) which will increase performance and not lose barely any visibility and may even improve it. Last time I jumped on I was getting between 160-180fps sometimes tipping 200 with a 5800X3D and 3080. That was a good month or so ago so fully expecting it to be lower now.
Multiplayer I was hovering around 210-220.
19 Sep 2009
Riedquat system
Tried Rebirth at 3440x1440. Using Extreme preset and DLAA was mostly around 135/140 FPS but fluctuated anywhere between 115 and 160. Tried again but this time with Fidelity FX CAS instead of DLAA and I would say was at least 40 FPS better on average :p (RTX 4080)
DLAA did look nice though tbf. As mentioned above there's a few settings that impact performance that might be worth turning to low - Shader Quality being one of them iirc.
6 May 2009
Thanks both. Ideally I just want over 97fps in action on resurgence modes. Dont mind turning down a few options if it means losing not much in terms of visual quality. At the same time its a 3090 Ti, so not a medium or low gpu graphics settings.
Not yet ready to splash out on a 4090 for some extra frames!
19 Apr 2012
Where does it say what hardware he's using and it doesnt show him playing either (to show the fps):confused:
I think its meant to show you which settings aren't required to be cranked up rather than which hardware its on. Alba performance had a really good one but for WZ1, He showed the exact FPS drops by each setting.
5 Jun 2005
Southampton
Played tonight on multiplayer with my work lot. Skill based match making so definitely broken or the player base has dropped badly.
For me I am struggling to keep interested. And the amount of attachments on guns is becoming a joke.
I copied a 'top load out ' video from YouTube and took me ages to find everything needed. I had to keep passing :D
Caporegime
8 Jan 2004
Rutland
Yup weapons are an absolute mess, 20-30 of every item but everyone uses only 2 or 3. The aftermarket parts are always meta for a few weeks before being nerfed, everyone runs one of a handful of weapons. They could just remove the MW2 guns at this point, they're just clutter.
5 Jun 2005
Southampton
Yeah it's a mess along with the actual game menu! The whole interface needs a makeover.
They could learn a lot from fortnite to be honest.
