This is getting ridiculous (energy prices - Strictly NO referrals!)
23 May 2006
Agile is all about when.
If your a heavy user in 4-7pm then no
If you can avoid most usage at that time then quite possibly a good move
Are you an octopus customer, if so check out
You can look at history and compare your consumption (very top left)
that link is interesting but i dont think it works for me....... i am on intelligent octopus and it thinks my average kwh cost is quite high. does it support intelligent octopus when it gives out of normal tarif shedules or does it just assume 28p or what ever 5:30-23:30 and 7.5p 23:30-5:30?
for instance in january here is a very obvious one. With that high use it would have involved me charging my car.......... which means the lions share of that would have been at 7.5pkwh. there is no way it would have cost me £11.84
DateConsumption (kWh)Your tariff average (p)Agile average (p)Your tariff cost (£)Agile cost (£)
14/01/202446.5325.1518.1711.847.72
4 Aug 2007
Wilds of suffolk
I think it just gives you your tariff average, I did mine myself in excel when looking but its hard to take account of how your behaviour would/could change
So I think its an ok estimate if your on a standard type tariff but pretty iffy if already on a smart TOU tariff
18 Oct 2002
7th Level of Hell...
Did you find a source for the claim that you are funding the infrastructure yet?
Did I say that? Cant seem to remember saying that. I'm sure you can help me out there :confused: but its funny... In my head I put money on it being you that brings my "subsidising" post up so you didnt disappoint. :cry:
EDIT - What I may have said is that certain regions pay more than others and that these regions also produce the bulk of the electric for the lower SC paying regions who use it. If you can point to the bit that's incorrect there, I am all ears
1 Mar 2010
So the octopus compare tool is crap and doesn't remember your usage profile across the day to accurately tell you what cost with other tarifs would have been
- like I'd suggested
28 May 2010
Leeds
Thanks for this - based on the comparison link it said I would have saved 42-46% over the last 4 months, so I've signed up
15 Nov 2007
Sheffield, UK
You talking about this octopus compare or something else?
23 May 2006
I wouldn't say crap.... just not intelligent enough to deal with intelligent octopus.
for agile or SVR or tracker i guess it works
9 Dec 2010
Think i've asked this a while back but don't remember getting a response.
Anyone here gone from E.ON to Octopus? If so, has your energy bill dropped at all? I'm currently doing gas and electric through E.ON.
1 Mar 2010
yes that one ..
so if you compare across multiple days ie week or month. will it give you the total for both Agile & tracker, by calculating the sumfor each tarif having compared those historic days individually. ?
in the excerpt bigmike included - agile average * consumption != agile cost ?
15 Nov 2007
Sheffield, UK
bigmike is refering to the compare feature in the agile portal which yes, is hot garbage with its average on smart tariffs!
In the Octopus Compare app it does as you asked, it calcs the price per half hour as you would have consumed it on either tariff (you can add intelligent go, flux etc) for each day. For weekly/monthly it adds those individual days together to produce your weekly/monthly comparison price. It is accurate :)
14 Jan 2018
Hampshire
Because this idea that you are subsidising the south seems to have no basis in fact. So I just asked for you to back it up. Fact is the supply infrastructure in regions is not the same and that is the point, you actually seem to be asking for other reasons to subsidise your higher costs rather than the other way round.
18 Oct 2002
Hmmm... I'm not sure you read what I wrote properly. I put the word subsidise in quotes and even explicitly stated why I put it in quotes as I can't think of a better word i.e. a more accurate word isn't coming to mind. I then went on to try and explain what I meant. So to pass off an OPINION as if I am stating facts and asking for proof is a little off but you do you.
1 Mar 2010
so which was better for you across previous months tracker or agile - my calculation has tracker, by some 20%, w/o considering common standing charge,
we also use pretty much the same electric across winter, so discrete comparison of specific months (if that's possible with app)
wouldn't suggest a switching strategy would be optimal, but we had a mild winter, and you can't instantly switch anyway.
15 Nov 2007
Sheffield, UK
For me every month since Dec has been cheaper on Agile - over that period it works out to be just touching 20% cheaper than tracker. We weren't switched for most of that time however so i expect we'll actaully get a few more % as theres effort not to run things like driers or dishwasher loads during expensive times. It'll be a tad lower now because the April agile adds a few pennys more per day to the SC. My switch was done online, completed in an hour or two and was live the next day.
Caporegime
21 Oct 2002
Here
Tracker is based on agile as an average. So if you load shift to cheaper times it will always be cheaper.
Plus SC lower on agile
4 Aug 2007
Wilds of suffolk
So from what I can tell on the grid and as ever its tricky to find much detail.
The costs of the grid are shared (unknown) split to the generators and the consumers.
Again unclear if the users are charged via SC or units. Suspect its SC but its not certain.
I guess its another conversation in that areas with adequate generation and no real need to send energy out are having to share (socialise) the costs to get energy to low producing and high consumption areas (London/SE).
Without the high demand down there some of the national grid work would not be needed.
It does seem a little out that the national part of the grid needs to be socalised even with areas with vast excess of generation not needing any grid in effect, but the rest is localised and hence your pretty much always going to socialise the big stuff and yet the generation is typically going to be in the areas where the population is lowest and hence the areas where the generation is likely to be built.
