- 14 Aug 2009
Sorry, what?
C2 is 93.2cm wide
AW34 is 81.5
Including the small bezels (can't recall how big it was on the AW34 it is at least 10cm wider lol) Personally I will take one decent size monitor over multiple ones because cba with wires and bezels are distracting.
![](https://i.postimg.cc/FfhCS2Zj/aces-2024-04-28-20-41-32-623.png)
Look at the image above. With a 16:9, could be 720p, 4k or 16k, doesn't matter, you'll always see only the center part - from the tank status to the edge of the map. With a triple screen setup the FoV grows a lot and in a situation like that, I can safely stay behind cover and see who's moving. Can't really do that too well with one screen.
Other examples:
![](https://i.postimg.cc/SYWmZnXX/aces-2024-04-28-20-33-43-032.png)
vs
![](https://i.postimg.cc/18Y1rGWC/aces-2024-04-28-20-33-26-182.png)
Or
![](https://i.postimg.cc/KKMcKpZr/aces-2024-04-28-20-32-53-285.png)
vs
![](https://i.postimg.cc/62KK89bt/aces-2024-04-28-20-33-10-470.png)
Basically you're playing with horse blinders. Put your palms along side your eyes, like a horse blinder. Then remove them.
The bezel, in my case, is less than 1cm, I think, for the main screen. The side displays are set with the bezels behind the main one, so they don't matter.
In other words, a square of 1x1 will always be that as a FoV, be at 480p or 4k. It will never encompass what 3 of those can.
