Anyone know if Duo tracks stuff?
Duo privacy data sheet is here https://trustportal.cisco.com/c/dam...eet/security/cisco-duo-privacy-data-sheet.pdf and the 'End-User Device Metadata' section.
Now I just have wait for ages while One Drive crashes /fails to sync / syncs hundreds of thousands of files. I don't know what's happening with MS One drive but since we moved everything over to it and share point we've had non stop syncing and access issues.
The amount of tracking from duo doesn't seem that bad to me, except perhaps the need for logging ssid details, which seems unnecessary.Duo privacy data sheet is here https://trustportal.cisco.com/c/dam...eet/security/cisco-duo-privacy-data-sheet.pdf and the 'End-User Device Metadata' section.
I think you've hit the nugget on the head here.If people have migrated an entire file server into a single library then it will perform like balls because people will be syncing metadata for files they have no interest in. This is why it's important to have a plan. For example you might have a folder where projects that are considered to be completed and closed go, as time progresses this will become the largest folder as there will always be more completed jobs than ones in progress or being quoted for, there's no need for everybody to have something like this synced to their device when it's so easy to open a browser and dig it out.
Thanks. Very good points. I'll talk about this with work.Yes not the worst, but for a private mobile logging details of the IP, SSID name, device serial numbers/IDs, host name (so my private network domain) wouldn't be acceptable for me.
When I monitored network traffic I also found it was sending details at times other than when in authenticating and although I could not decode what it was sending that is bad especially if it included location. Maybe it was a bug they've now fixed and for a work mobile all these details are fine and expected, but they should have a 'personal phone option' if companies aren't going to provide phones (or just use standard TOTP authenticator apps).
So, another week later and we still have issues with one drive and share point. There are a few different problems, but the main issue are:
- Files taking hours to sync or not syncing at all.
- Indexing of folders and files taking hours, in some cases days.
The IT dept have said the issue is possible because of the number and size of some folder locations. For example we have an archive area that has 5TB and one of the working areas with about 2TB.
Perhaps. We had a meeting yesterday and the IT guys said other departments were not having the same problems we're having.Sounds more likely, with that info to hand, that this has just been poorly planned and executed.
IT have said that too. They've asked us to use selective sync for folders that we want available offline, but we'll still need to sync to the whole 5TB even if we only access via a Web browser.You've got 5TB of data in a single SharePoint document library? Performance will be terrible if you sync a library like that, best to stick to accessing it via the web browser.
I'm glad it's not just me then!Our work uses SharePoint & OneDrive and it's absolute crap! Slow as hell and constantly creates duplicate files if you start moving a lot around (we had to do this for ISO compliance and it was left to each team to move their own files), not to mention having to wait for it to sync if you do that. At one point I had over 3000 files waiting to sync and it took days for it to finish, then it complained it couldn't merge about 100 of the files so ended up with more duplicates 'cos they can sod off if they think I'm going to open each file and tell it which one to keep. It also regularly errors out when trying to open simple things like image files (jpg, png etc). Whoever thought this was a good idea should be slapped around the face repeatedly!
Just saying
Oh, I'd forgotten that. Yes, open a file only to be told you need to re-save it! Why?! Pile of utter ****! Give me a proper file server any day of the week.I'm glad it's not just me then!
I can't understand why it's so bad. It's so bad I'm trying to find work arounds so I don't need to rely on it for instant access.
I find it's incredibly slow to open files even if they are locally available. It feels like every file that is opened is checked with the online version before being opened. On the face of it, that seems sensible but the result is lots of slow file opening.
I've got excel files that just will not sync. Whenever I open them I get a message saying that the file is unable to uploaded and I need to save another copy. If I save another copy that syncs but then the next time I open it the same thing happens. It's just a simple excel file. Makes no sense.
Yeah, I think our place has basically done a box ticking exercise to get ISO compliance too. I very much expect if they had a surprise audit they would completely fail. As for mobile apps, you can stick 'em where the sun don't shine. They're not going on my phoneWe've moved a lot of stuff over to it but so far I've not found it too bad, other than the constant signing stuff out and requiring signing in again, etc. some of the approaches and security policies seem more like they've done box ticking to ISO standards rather than actually implementing them in a way which would work best with a lack of joined up thinking between some stuff.
