- 1 Mar 2019
Hey, so I did all my latest upgrades. Leak tested overnight all good, I've been doing watercooling for years and am pretty confident with it at this point. I've been through leaks and things, alway just lept out of my seat and switched off the power supply
. Not had that happen in a long time though! but anyways, I finished my build, tested for 16 hours just the pump on full power. I moved it upstairs and after half an hour of gaming a pipe came loose and coolant sprayed all on the inside. I cleaned it all up, wipe everything down with alcohol wipes. triple checked every nook and cranny for hints of coolant (luckily my motherboard is shielded and its all dripped down through the bottom on to my desk. I isolated it to a pipe on my CPU block, the fitting was barely even half tight and the pipe just came out easily. I'm guessing this was just a brain fart on my part not double checking and the heat and pressure of full system use is what eventually forced it out. But could it be any other reasons. FYI, I cleaned it all up put the pipe back in, tightened every fitting up as much as I could and have been using it since with no issues or hint of leak. Just want to see what people think before I'm out of the woods. I'll feel confident removing the paper towels after a week if I've had no faults . I'm usually very relaxed about watercooling but with how expensive my parts are I'd be lying If I said I didn't pap myself.
