AMD - How To Overclock The Official Way Using Afterburner + Step By Step Overclocking Guide + Comple
Caporegime
OP
12 Jul 2007
United Kingdom
Question: once the ccc limits are lifted, is there a way to revert them back to default?
I was under the impression that the /xcl only impacted on the software, yet as far as I can remember and see regardless of format etc the ccc appears the same??
Can anyone explain? Sorry for noob question :/
Yes, instead of /xcl use /rcl. :)
31 Jul 2011
I flashed the Vapor X to 7970 Bios 1100 - 1450 (Sapphire)
Then I OCed to 1100 -1600 stable at 1.056 Volts
Unigine *8 *16 Extreme Tess
1224 (48.6 av - 26.1 low - 119.9 high)
An Nvidia GeForce GTX 680 2GB @ 1006 - 6008 scores 46.6 @ 1080 same settings (I presume @ stock).
3D Mark
GRAPHICS SCORE
8626
Not too bad... and total stable without a voltage increase.
http://www.tomshardware.co.uk/charts/2012-vga-gpgpu/01-3DMark11-B-Performance,2932.html
The Sapphire Radeon HD 7970 Toxic 6GB Lethal Boost is rated at 8421 (I guess its not clocked!!!). I'm happy with the card now.
It really needs the new bios.
It runs @ 76 degrees under load.
I'll be buying a waterblock for it before I volt it up.
2 Aug 2012
3D Mark
GRAPHICS SCORE
8626
Can you put up a link to that bios? Is it fairly straightforward to flash the bios? Not attempted that before. Sounds worth it for a stable 1100/1600 oc
2 Aug 2012
Also a bit of an aside but have you given virtu MVP a go? Gave me a good boost and helped with tearing in battlefield 3 when vsync is disabled
13 Jan 2012
United Kingdom
I have a problem, this has happened twice now,
When ever I set an overclock and go into a game, after a while the screen goes black and my voltage in MSI afterburner resets back to stock. Whats the reason for this? unstable?
2 Aug 2012
what are you raising the voltage to?
Sounds like unstable/voltage too high
31 Jul 2011
flashed mine to the 7970 bios as DRHF mentioned.
Much more stable overclocks :D
What overclocks do you get off stock voltage? I'd love to get over 1100 on the GPU, but it doesn't like to go higher.
Oh, I also found out that the Vapor X cooler isn't very good... @ 1.100 volts (1.8x in hwInfo 64) it registers 81 Degrees under load...
I really think it could reach 1300 easy with a proper cooler.
31 Jul 2011
I nearly forgot.
Make sure you use trixx not Afterburner for the overclock. I had a strange error yesterday with afterburner (I only use it for video recording), Trixx and CCC. Trixx will automatically over-ride CCC but afterburner doesn't for some reason since I switched the Bios.
It may just be an eccentricity on my machine though.
2 Aug 2012
I got up to the same as you 1100/1600 on 1.056
Raised voltage to 1.118 and was able to push the core clock to 1150 but there was a few artifacts here and there. Temp never went over 69 though running unigine. Got bored of watching unigine and had to sleep in the end though so experiments ended there.
Been using Trixx anyway, wasnt having as much success with afterburner (not saving profiles etc)
Caporegime
17 Mar 2012
ARC-L1, Stanton System
do you have to use the beta drivers to get this afterburner sloution to work? or can you use 12.8?
Use 12.8, all you need to do is what you see in the attached pic.
