I've had a bit of a play since and overall the main issue is the aux cooling and enclosure fan, the stepper whine is something new to me as my ender was silent but its not too bad with the door closed. As you say I don't think the supplied models are sliced with noise in mind.Ah ok, can see why being next to it through a stud wall could be a problem. My garage isn't so bad but sometimes I wish I kept it in my office when I forget to put shoes on for the cold floor!
Will try mine out at some point on the silent speed, haven't felt the need yet, it's a shame if it doesn't make a noticeable difference.
Have you tried different models? From what I understand the pre sliced bench isn't ideal. It might be worth looking at the infill pattern used, some of them will mean more movements resulting in more noise.
I also think the plastic enclosure amplifies the clunkliness of some of the motion. But with the reduction in print time coming from my ender I possibly won't need to print overnight.
I could suggest it, but I don't want to get stabbedThinking out of the box how about move your wife to the garage? Just a thought![]()
She struggles with sleeping as it is and starts work a 4am so its best I tread lightly.I think a big part of the issue is the fact its all plastic so it resonates more from the fans and the stepper noise, but as you've suggested knocking the chamber fan down helps a lot. It's not an unbearable amount of noise under normal conditions, just a lot louder than an ender 3 v2 with stock fans.On my X1C I can print and be in the same room without it being annoying but I do mostly print ABS so everything is enclosed.
But other than that, its an impressive machine! The speed and print quailty combined are impressive enough, the AMS is great if wasteful with coloured prints (not why I bought it), and the fact it just works out of the box without going over it with a fine tooth comb makes it well worth the price.
