BMW and M Power Owners
Man of Honour
2 Jan 2009
If you want the extra responsiveness at roundabouts for example, the easiest thing to do is push the gear lever to the left. This will keep it in the best gear, cut out any stop start, and it will respond as fast as any manual can.
Not quite sure how this works on the very latest cars with the new style gear switch thing.
5 Apr 2009
A lot of this sort of thing boils down to driving style and whether the inputs a driver is giving the car are leading it to respond ineffectively.
I've never experienced this roundabout hesitation, whether in the 440i with ZF or the vRS with DSG yet other people criticised the vRS DSG as if it was genuinely dangerous to try and navigate a roundabout without switching to manual.
Man of Honour
17 Oct 2002
This is the biggest problem for me with the autos. The (small) challenges I have with them can be overcome with manually changing gear, or using sport mode, for example, but that's just to make them as good as a manual - so why not just get a manual?
Because there are numerous areas where an automatic is a superior gearbox to a manual. I can think of almost no real benefit to a manual except one - on the right road at the right time of day in the right car, nothing will beat manually shifting gears yourself as you enjoy the road. This is perhaps 1% of driving and if you're buying a 4 cylinder diesel saloon car its probably 0.1% of driving.
Meanwhile, a manual gearbox is inferior in traffic, it's inherently less smooth to drive, it's more effort when you're just driving normally, it's less able to handle higher power and torque, it's frustrating and annoying to have to keep changing gear to keep a car in its narrow power band if its got something like a 4 cylinder diesel in it (Honestly, a manual 4 cylinder diesel is about the worst driving experience its possible to have. I'd probably rather just have an electric car than one of those. Automatic makes 4 cylinder diesel actually work - I can't see how anyone can genuinelly find enjoyment from changing gears manually with a 4 cylinder diesel engine!?).
We have one of each - the Mini has a manual gearbox and a small 1.5 litre petrol turbo engine. It's a small and light car, it's fun to drive and the manual gearbox doesn't detract from this in any way (Plus the auto in the Mini is rubbish). But when you're driving big heavy saloon cars or similar, the manual just brings disadvantage rather than advantage.
It has always been difficult enough to find good cars of this type with a manual gearbox - these days its almost impossible. Even if you disagree with everything I've said above, the fact the manual gearbox on the current 3 Series was only available for a short time on the base cars only with the poorest specification should be enough of a reason to just rule it out. I think the whole argument is largely irrelevant because the number of 3 Series ever sold with a manual gearbox and the upgraded stereo must surely be a single figure number.
If you still really want the enjoyment of a manual gearbox then I have to wonder why you'd want a 2 litre diesel saloon car to go with it.
Also, as quick as the shifting is, it isn't quick enough. In 6th gear I apply pressure and I'm off - no gear changes required.
I'd imagine the time taken from decision to arriving at your chosen new speed between the auto and the manual would be at best identical and more likely quicker in the auto, regardless of the fact you perceive it down shifting as adding time. It'll downshift almost immediately and then instantly have more power and torque available for the acceleration than it would have done had you just accelerated in 6th year. If you want to stay in gear and accelerate you can do that with an auto as well, you know. It's up to the driver whether it kicks down or not?
I used to have absolutely the same view as you and always got the manual not auto but the leap forward with the introduction of the 8 speed in 2008 was so huge that it changed everything for me.
That said, I will definitely try an auto in case it's a lot better - I have nothing against having one if it isn't as annoying as it has been on my F31 and S5. Perhaps it's a different experience in the 530d and M340i due to the added torque. The S5 was better than the 320d and I suspected at the time that it was for that reason.
It is likely to be very car and engine specific - I drove an Audi A6 with the 200bhp 2 litre petrol once and that thing was very annoying on roundabouts, doing basically everything you describe - accelerate, nothing, nothing oh there we go, great. But this is as much the engine as it is the gearbox. Pick the right engine.
Though I do remain surprised by your experience with the S5. I've never driven an S5 but on paper it has everything you need for the ideal automatic experience - was it the 8 speed?
9 Mar 2004
This is what I do on the rare occasions I feel the need, most common is when I'm joining fast moving traffic where I'm stuck at say, 40 and the response is known to be a little sluggish. Pop the stick over, the throttle will respond instantly when you put your foot down. Then pop it back over and cruise! I can't say I've ever struggled at a roundabout but I do always disable auto stop/start too.
14 Apr 2014
Sunny Sussex
I hear what you're saying (or see it :p ). I think for most people auto is great - I always recommend them because of how sloshy the ZF8 is.
But:
  • I don't drive in traffic - when I do I have my Porsche and gucci belt at the ready, to show everyone I'm a high salary earner.
  • I actively like changing gear - me and my other half have a background in mechanical engineering, so we both enjoy the engagement from physically moving a gearstick, pressing the clutch and getting that sweet gear change. Engine is irrelevant for this.
  • Doesn't need to handle higher power and torque - it's rated for the engine and it's not going on a dyno
  • It's not a powerful car - don't need it to be quick. Ample low down torque + gears I'm in control of = smoother experience.
As previously mentioned, I don't like driving manuals because they're sportier - I think a dual clutch is much sportier, I like driving them because of the direct, physical control I have of the gears.
Just for clarification - I'm not sure a manual 981 would have worked for me. I don't think it has enough torque in 6th.
My mum used to have a manual A5 2L TDI. The car was a dream on the motorway. Effortless overtakes and speed control with absolutely 0 extra thinking required, other than doing standard checks to overtake.
Much like my manual 135i. It's the best motorway car I've owned with 450nm of torque. If it wasn't for the 34 MPG I get on a run I'd keep it :p
You're dead right about them being rare, though. I think there were 6 in the country with HK when I last checked. Having not driven an auto yet though, I'm currently happy to wait as long as I need to find the right manual 3 series with HK.
It's not just about the speed, it's the number of decisions to make.
You're probably thinking "what, the decision to pull a paddle twice?" - it's a small thing, I know. But I can't describe how much I love how effortless manual driving is on a motorway.
Regarding the staying in gear. I found that the amount of acceleration I needed in a 320d (and the S5 actually) always made it hesitate, almost like it couldn't work out whether to stay in gear or change down. If it did change down, I found it would go in to 7th, and then work out if it needed to change again - often doing so. I found it jarring.
PDK - foot down, picks a gear, goes. On the way to work today. Down to 50 as a lorry is overtaking uphill. As it moves over, foot down, 2nd IMMEDIATELY and I take off.
Much quicker and hence tolerable. Still prefer torque pulling me through it as changing to 2nd and 3rd all the time drinks fuel.
From memory, exact same box as in the M340i. Sport mode was quick but it would stay in 7th regardless of (legal) speed on motorway. Around town it'd stay in 2nd, maybe 3rd at 30. Lower torque in the S5 compared to M340i. 440 vs 500nm I think.
I think you're right about it being engine specific. It's why @Robbo doesn't have this issue - 730d before I think and now an 8 series?
I don't think the ZF8 suits the 2L diesel. Not enough torque for 8 gears and it's always hunting.
In the cars I've owned, knocking to the left locks it in gear. But if I'm having to do that at every roundabout, may as well have a manual :p
Edit: Feel like I go on about the PDK a lot - but it's genuinely a very nice package. In the name of science, obviously, if anyone is down on the south cost and wants to do a back to back with PDK and ZF8, let me know :cool:
18 Mar 2010
2014 335i
I have a "turn indicator rear right failure".
I can here the indicator sound seemingly at double speed, but the light does not come on on the rear of the car, only the wing mirror.
From a quick Google this seems to be a common problem.
I was wondering if anyone can give me some insight into repair under the extended warranty. We have named component coverage, is this fault likely to be covered?
Do I have to put the repair through my local authorised dealer (syntner in cow roast), or can I get my local independent specialist (dmworx) to do it? If so what is the procedure for the latter option.
Man of Honour
17 Oct 2002
I can totally understand that. But to then go for a 2 litre diesel? :D
This is the bit that really confuses me. I don't understand how you are driving on a Motorway for this to be an issue. There is none of this on a Motorway with an auto? There are no decisions to make about gearing at all, the car just does it for you? It's the part of driving where things like acceleration are least useful anyway.
Nobody with an auto needs to think about anything to do with the gearbox when Motorway driving, especially not if they've got a really good gearbox.
You are the first person I've ever seen claim that a manual gearbox means you have less to do when Motorway driving than an automatic :D
Years ago my Dad had a few 520d with the 8 speed auto - they were fine...
You don't need to do any of this to negotiate a roundabout with an automatic gearbox :D
Man of Honour
17 Oct 2002
2014 335i
Have you changed the bulb?
9 Feb 2009
Sunny Fife
2014 335i
Looks/sounds like just a blown bulb, easy to do yourself or if you can't there are places that will do it for you quite cheaply.
14 Apr 2014
Sunny Sussex
2014 335i
Had this on a 2014 3 series.
Is the entire light cluster non-functional, or just the indicator? If the latter, it'll just be a bulb.
5 Oct 2004
I found the ZF8 in the M340i to be a lovely auto box, the one issue would be slowing down for roundabouts and then accelerating if you had almost stopped, but not 100% (slight delay whilst it works out you are no longer stopping and want to accelerate again). This is about the only issue I have had and where manual clutch control won.
I didn't tend to drive around in Sport / Auto too much unless I was out of town as it held onto the gears for longer than you'd like. Generally use a mix of modes depending on how/where it was being driven (and the time of day, consideration for others):
Town or Motorway Driving: Comfort/Auto - effortless to cruise, start, stop and deal with traffic.
Out of Town/Fun Driving: Sport/Paddles, get caught up in traffic/roadworks and stick it back in Comfort/Auto again unless there is a sensible place to pass coming up and it does a great job of changing down gears for you when slowing down for roundabouts/junctions so you don't always have to drive like a full manual.
M3 is similar, although it's Efficient not Comfort (not sure Efficient is the most apt term...).
15 Aug 2011
Just tried auto park for the first time, have to say I am very impressed by the quality of the parking and the getting out of the smallish space. The car did take quite a few attempts to get straight, maybe a few more than I would have needed, actually a very relaxing experience!
Then tried the reverse assist, I normally reverse into my drive, neighbours car in the drive next to me, bloody car wanted to reverse into it according to the reverse lines on the camera.
Any tips on using the reverse assistant?
14 Apr 2014
Sunny Sussex
Engine not really important. Diesel just because cheaper and more fuel efficient on long journeys. Going to Edinburgh later this year along with some other road trips planned. Also 320i manual are rare as heck
I guess more dual carriageway - my local motorway (A3M) is 2 lanes. And A34.
In those situations, I find a frequent need to accelerate hard ish which is where the ZF8 was always annoying.
In a manual I literally just have accelerator to do. ZF8 if I didn't change gear myself it was jarring/slow to change down and frustrated me. Manual = go or go quicker or go slower. 135i will do 35 in 6th and give me ample torque to get to 70 easily.
In my experience, I do. Come up to roundabout in 3rd, as I go to accelerate it changes to 4th or 5th. Every damn time. Then has to re think which gear to be in. 320d and S5 did the same thing.
Don't even get me started on stop start :o
21 Jan 2010
2014 335i
lol what? It is the bulb dude.
26 Oct 2013
Leicester
Looking for advice on warranty.
Had quotes for my M2...
Comprehensive:
£0 excess £1309
£100 excess £995
£250 excess £793
Named component:
£0 - £1034
£100 - £827
£250 - £666
All above exclude roadside assistance, as I have AA cover via bank account.
There's also driveline, however I am not tempted as the claim limit is £5000, which I don't think would cover a 'major failure' of DCT gearbox or engine
I am tempted by named with £100 excess, however are there any major components that I would be missing out on that I should go for comprehensive for? I know all the screen, interior bits etc wouldn't be covered but my major concern is engine, gearbox, and diff.
14 Apr 2014
Sunny Sussex
I put it in manual mode on the motorway and use the paddles if necessary. Each to their own and whatnot
I don’t get why people keep saying this. If I’m putting it in manual mode why not just get a manual? I’ve point out a few times that I enjoy changing gear manually.
Nothing to do with speed or sportiness
But 35-70 allowing the auto to kick down will be much quicker than just staying in 6th? And require no intervention by the driver.
Don’t care about speed. It’s about ease.
As I’ve pointed out a few times the kick down is jerky, clunky and annoying. Only the PDK is silky smooth in this instance.
14 Apr 2014
Sunny Sussex
Comprehensive:
£0 excess £1309
£100 excess £995
£250 excess £793
Named component:
£0 - £1034
£100 - £827
£250 - £666
Is it worth saving £150 on an M2?
It is, in the eyes of BMW, an expensive car with expensive repairs.
For £10 a month I’d much rather have peace of mind :)
Man of Honour
2 Jan 2009
Did you not say you had an F31 with the ZF8? Knocking to the left doesn't do this. It downcogs by 1 gear and engages the sport mode for the gearbox, and cuts out stop start. It's still much easier than changing gear in a manual.
I recently drove a new Macan GTS PDK and the PDK is good, but in normal driving it's certainly no better than the ZF8.
Now I will grant you the DCT in my M4 Competition was far from ideal for daily driving, it's ok, but the ZF8 is far better in traffic etc.
I'd be very interested to sit next to you and observe these things you mention, I've never had my ZF8 try and change up a gear as I approach a roundabout for example!
