Somewhere that specialise in hydraulics and bearings will have a ring you suit your block.If its been used with coloured coolant
Then yeah may be a good idea
Neglected mine due to health issues
And the red coolant did clog the cpu block microfine
Though if they're clogged
You should get an idea by the flow rate
If you don't know what block it is
And the O ring does need replacing
You might have to make your own
Or get creative with some instant gasket or similar
I find this hard to believe.... When i cleaned my block it was not a ring.Somewhere that specialise in hydraulics and bearings will have a ring you suit your block.
The blocks I've used have always had a specifically shaped gasket yeah. I refer to them as rings out of habit.I find this hard to believe.... When i cleaned my block it was not a ring.
If a ring yeah sure find something that will fit but not a wierd polygon shape
