Corsair Carbide Air 540 Builds
19 Aug 2013
figured it out heres mine
31 Dec 2006
I'm guessing there is no solution you can buy to cover up the hideous bottom of this case? I've seen a few user mods, but not sure how complicated this would be to achieve? Ruins the case visually for me, staring at those racks, especially when you have lighting in there.
Man of Honour
13 Oct 2006
I've not tried it as I've stuff mounted in the way but I'd assume it would be fairly easy to cut an acrylic sheet to shape and find a way to attach it - assuming you aren't actually using the HDD bays.
17 Aug 2005
Gloucester, UK
first off - sorry for the thread revival!
Just got 1 of these cases for the wifes pc, just wondering how you guys have got the fans setup, its running with a h110i gtx in the top.
which would be the best setup?
front intake?
back exh?
top to intake to? and in push or pull?
thanks!
26 Aug 2013
front intake?
back exh?
thanks!
Had good results with front intake, back exhaust, top exhaust push. Seemed to maintain positive pressure despite more fans exhausting, due to rad obstruction I guess. Stock fans are rubbish though.
