cpu 89 degrees under load
1 Dec 2015
I think a good clean will get your temps down by quite a bit.
I wouldn't replace the stock cooler unless it's particularly noisy.
Also check that your power supply fan is working.
OP
6 Oct 2012
(do-or-die) Wye, Ashford, Kent, UK.
before i consider buying the arctic 7 cooler, i would like to see how much difference a good clean would impact upon the performance of the cpu.
i have the paste, isopropyl alcohol & cotton buds (is kitchen roll ok too?).
one problem:
should i remove the mobo to re-affix the stock intel cooler?
there is no back plate access to work with the stock cooler stand clips.
