- 4 Jun 2010
big pics are big!
big pics are big!
1* thread now
Shayper,
I have resized the images :O and below are the links in order ie the first image here is the first image in your first post; i have resized them for 800x600
1)http://img9.imageshack.us/img9/9492/30721184.jpg
2)http://img841.imageshack.us/img841/8122/37260129.jpg
3)http://img232.imageshack.us/img232/9061/30235913.jpg
4)http://img13.imageshack.us/img13/4729/76228512.jpg
5)http://img807.imageshack.us/img807/2520/43447706.jpg
6)http://img692.imageshack.us/img692/7876/49768649.jpg
7)http://img810.imageshack.us/img810/3698/52817762.jpg
8)http://img52.imageshack.us/img52/1807/18346215.jpg
9)http://img827.imageshack.us/img827/3803/55397004.jpg
10)http://img838.imageshack.us/img838/8935/imgbol.jpg
11)http://img6.imageshack.us/img6/7226/88961666.jpg
12)http://img16.imageshack.us/img16/8718/60831085.jpg
13)http://img88.imageshack.us/img88/7805/68903934.jpg
14)http://img21.imageshack.us/img21/4273/50222788.jpg
15)http://img534.imageshack.us/img534/5804/img2cu.jpg
16)http://img232.imageshack.us/img232/3394/22050827.jpg
No worries one last question though and I will leave you alone! How easy was it to mount your gpu block? And did you just follow the instructions that came with it?
Thanks
Thanks
I think because I've never really used or even seen a watercooling system outside of pictures. I'd prefer to get a kit. Just so I can build it up and watch it running and working as it should.
Maybe then, I can look into customizing the kit. But for my first attempt, I'd like a paint by numbers kit
Thread updated with links, pics, and reformatting
Haha
Think it had a lot to do with Erika saying how cheap her blackberry would be to replace in comparison. Was an epic win though
Only if the screen is cracked
Thanks for the guide - just what I was looking for.
I'm looking to go WC at the end of Aug. Currently have a Corsair H70 cooling the CPU which *seems* to be doing a decent job. It's the 480gtx which is causing me problems.
My PC is stuck on the floor in a corner (missus' decree) so I don't think it's getting enough cool air into it. With our odd spat of hot weather recently in the south, the gpu fan went nuts - rpm'd its nuts off. So i want to go WC.
My question is - given the guide posted in the OP, it means only specific gpu blocks or a cover plate. But what about the 580 'hydro' cards with the plate already built into it? Is that sufficient or should I not even consider them? (Complete WC noob here).
