lies, 21+ should be illegal
That depends on how you personally feel in the given temperature.Exactly.
Only say hot when it's near our over 30.
This is warm at best.
I'm fine with this interpretation.Remember that when you see a weather forecast on TV, in a newspaper or on the radio, that anything from 20 degrees upwards is going to be warm, above 25 degrees is hot, above 30 degrees is very hot. Below 20 is cool, below 10 degrees is cold, and below zero degrees means that it will be icy outside as the water will freeze and it will feel very cold outside.
That's fine, but as I stated it depends on how you personally feel. You can have someone walking about in shorts and tee shirt in winter where most would be togged up and people wearing coats in summer when most would be stripped out as far as they could goTaken from a Google search -
Well, I think you could argue that how you feel is how you feel. 'It's hot' and 'it's too hot for me' are two different things, surely? I would suggest someone stating 19 degrees is 'hot' is basically wrong. Yes, it might be too hot for them, but it's not 'hot' by the popularly accepted definition in the UK.That's fine, but as I stated it depends on how you personally feel.
TrueWell, I think you could argue that how you feel is how you feel. 'It's hot' and 'it's too hot for me' are two different things, surely? I would suggest someone stating 19 degrees is 'hot' is basically wrong. Yes, it might be too hot for them, but it's not 'hot' by the popularly accepted definition in the UK.
No not even close, yes being overweight can be a problem(I am classed as obese due to weight but I have no underlying fat layer on my arms or legs just a big abdomen, even there, the amount of fat isn't excessive) but medical conditions can also cause these sorts of responses. Arthritis is one, I have atrial fibrillation so as it gets warmer I feel worse.It’s very presumptuous, but I’m sure many of those who complain of struggling when it goes over 16 degrees are overweight. I had an overweight pal (RIP Lennie) who sweated like a Turkey at Christmas as soon as it got over 14-15 degrees.
I also have atrial fibrillation and am fine in the heat.No not even close, yes being overweight can be a problem(I am classed as obese due to weight but I have no underlying fat layer on my arms or legs just a big abdomen, even there, the amount of fat isn't excessive) but medical conditions can also cause these sorts of responses. Arthritis is one, I have atrial fibrillation so as it gets warmer I feel worse.
Everyone is different. Really don't know why it's so hard for people to just accept others don't like heatI also have atrial fibrillation and am fine in the heat
Yes you areEveryone is... Wrong?
robfosters said:Everyone is... Wrong?
robfosters said:I also have atrial fibrillation and am fine in the heat.
If you lost weight and got to a normal healthy weight, you would deal with it better. You’re hearts in a fib and is struggling to carry that weight around. It’s not all about fat, there’s a multitude of issues that being obese in the heat can cause.
I definitely cope with heat a lot better since losing weight. I used to hate it too and would surprise people at work how quickly I would be turning on the air conditioning.It’s very presumptuous, but I’m sure many of those who complain of struggling when it goes over 16 degrees are overweight.
