Hi,
I was bought this card as a present quite some time ago - and had opened it at the time and had a look at the contents but with work commitments over the last year, I haven't had time to upgrade my PC with IT. Now that I've gone to do it, I cannot see how to connect it to my PC PSU.
The PSU I have is a Gigabyte UD850GM. Looking online it would appear that this PSU is satisfactory power wise for adding the GPU to my system. My issue is the cable required to do this. There's no cable in the box with the 3090TI that would connect to the card and the PSU - it appears I need a 12PIN (2 rows of 6 pins) mini connector on the 3090TI side and I think 3 x PCI-E 8PIN connectors on the PSU side.
Can anyone point me in the right direction to get a cable? There's a number of cables that fit the bill from China, but I'm a little wary to go get one and I'd rather purchase the correct one from a recommendation here if possible.
Thanks,
KbJunkie.
Thanks,
KbJunkie.
