So today has been a bit of a slow day haven't had much to do really except planning for the next stage which is tubing.....after i manage to get my top panel sorted (Thanks Parvum and 8 Pack for sorting this out for me) and getting a radiator which needs painting and buying fans for it. -_- spending all them pennies (Any donations welcome hahaha)
One thing i did manage to do was fit in the motherboard a gigabyte SOC champion, I'm fully aware of the colour of it but do not fear.....parts are going to be sprayed/painted green and purple and all the PCI-E lanes and all the DIMM slots will be occupied blanking out the majority of the board......You may ask why did i pick this board? Well I got offered it at work not going to say no to a cheap board.
I managed to do some tubing.....well i managed to fit in two tubes only to see if the pump and res were in line and to see if it was possible to get a tight angle fitted into the radiator which suprisingly fitted really well.
The 90 degree fitting was a bit of pain which my sausage fingers it wasn't easy to attach and screw in.
Over all its been slow but productive day, least I know the tight fitting fits and it is not moving.
