*** OFFICIAL HOME NETWORKING FAQ ***
OP
29 Jul 2011
Near Northants / MK
Found the initial post interesting but I'm getting on and bits of this are well over my head. My issue is this and I look forward to any basic info., suggestions and recommendations.
We live in a new build with FFTP since moving in we have used See the light as our provider along with their supplied technicolor TG589vac V2 router. Generally it works fine but WI-FI connected items often drop out for a short period of time before coming back, it has become very frustrating. We have contacted their helpline and they suggest that one of our attached pieces of equipment is the problem. However having viewed the estate Facebook site many others have had the same problem and they have changed their router and now do not suffer these issues. We don't game but we do have a few streaming devices attached to TV's although they are used infrequently. We also have a smart TV, my wifes phone as well as a business computer and my laptop although these are not connected to the wi-fi all of the time. Finally we have a two IP 4MP security cameras that work over a Powerline. My wife and son occasionally need to work via Teams and Zoom
I'm hoping that we can solve these problems like our neighbours by replacing our router. I have been looking at WI-Fi 6, perhaps tri band routers but i am unsure if I need anything else to connect to the fibre supply (some mention of modems?) I'd prefer just an easy one box setup like I have now. I don't think we are heavy wi-fi uses but i do need a reliable product that is not going to cut out regularly particularly during video conferencing.
What do you think I need for a more reliable wi-fi and any recommendations for a quality router that is relatively future proof and isn't ridiculously priced? Thanks in advance for replies.
Hey, this could be a couple of things but I think what you've likely got is devices with low wifi sensitivity sitting on the edge of an acceptable signal losing their association.
It's likely not the router elements fault, more simply the wireless part - I assume the devices you're experiencing challenges with are likely to be further away from the router.
You want to look at a wireless access point potentially in a different location, or much simpler to install a wireless mesh kit like WJA mentioned :)
29 Dec 2002
Just noticed this and gave it a once over, I appreciate you taking the time to put it together, but a few things jump out:
You've merged ADSL (8mbit) and ADSL2+ (24Mbit), also no mention of SAT or wireless WAN connection types?
Powerline is technically three different products and the most common two are abhorrent, they're also marketed using full duplex speeds, so a 600Mbit kit will only ever manage a maximum of 300Mbit in either direction, anything below 600mbit will historically have 10/100 ports and be limited to such (if you're lucky).
5e does 10Gb, so does 6, you really don't need 6a or 6 unless you are doing long runs, but 6 and especially 6a will give you the potential of running much longer than 5e, but most residential runs are unlikely to be a problem... unless you have a servants wing. Also solid core for structured, stranded for patch.
Rather than disagree with your hardware recommendations, why not simply remove them as any reference will be outdated quite quickly and really should be made based on the individual requirement rather than a generic recommendation.
PFSense is a hard no for me, Netgate is literally everything that is wrong with open source software. They literally ran a hate campaign against OPNSense because they forked an open source project, registered the opnsense domain and spread hate/abuse about them along with quite vile and disgusting personal attacks, did similar with r/opnsense, mishandled the U-turn on the AES-NI requirement with no notice months after warning everyone to upgrade hardware, outsourced the wireguard kernel/main line project to a convicted felon who had jumped bail, fled to the EU and had to be arrested on an INTERPOL warrant and extradited, then was convicted and served time for some pretty serious crimes (they dropped the gun charges iirc) who then went on to do an absolute hatchet job on the code which was about to be mainlined before Jason (WireGuard dev) pointed out it was deeply flawed and re-wrote the whole thing. Netgate being the shining light (or at least something that rhymes with it) of the open source world blamed Jason for calling them out on it. OPNSense just used the user space module and ran happily the whole time with no drama and a slight speed penalty. At the very least you should include OPNSense, Sophos XG, IPFire, DDWRT and in fact pretty much anything else before PFSense a a recommendation.
You don't need a VLAN capable switch for isolated SSID's - Unifi controller offers this as standard, I use it daily for exactly this purpose.
I appreciate it's a lot easier to pick fault with others efforts than actually do what you did and take the time to put something like this together, please take this in the spirit it's intended as feedback to make it better, not criticism.
