** PHANTEKS ENTHOO PRIMO - THE ULTIMATE WATERCOOLING CHASSIS **
29 Aug 2013
That is a very nice looking case! Adding that to my shortlist for sure! One question - it says a 480 will go in the bottom, but the side panel looks like it'd get in the way?
20 Jun 2013
The video they did initially shows A Hardware Labs 480 rad being too wide to fit in the bottom, but that's because the rad has a shroud that makes it 133mm wide.
In an actual build video they fitted an Alphacool Monsta 480 rad in the bottom with push pull, the Alphacool is only 124mm wide.
The Phanteks manual says that the bottom can support rads of 125mm width. Hope this helps.
1 Jul 2011
Jesse's build at end of his review has a 360mm radiator in the ceiling, the Alphacool XT 45 and a 480mm in the bottom, the 480mm Monsta radiator in push/pull configuration
themodzoo.com/forum/index.php?/page/articles.html/_/reviews/cases/phanteks-enthoo-primo-full-tower-review-r67?pg=6
Edit: Beat me to it. Guess that's what I get for getting another cuppa. :D
29 Aug 2013
Awesome, thanks.
20 Jun 2013
Np. If you're going with Alphacool rads in the 480 flavour you may be in for a wait. They seem to be out of stock across Europe in anything other than the 45mm thick models. Estimated delivery date of new stock is November :(
23 Jul 2007
Worcester
I've gotta say, that looks fantastic, and I love the simple things like having to go around to the other side of the case to mount the HDD's, so that the actual side window shows nothing BUT your pride and joy - nobody wants to see the crap!
Tempted as an upgrade from my 800D, but I was planning to go smaller.. what have you done OcUK
1 Jul 2011
Just waiting for mine to arrive... next month. :(
Best written review and build I've see is Jesse's on TheModZoo.
Best video review is Bill and Jesse's MonsterMod review on YouTube
1 Jul 2011
Really does give us lots of options for doing things. I'm almost embarrassed building mine air cooled. But it will be a great aircooled case!
There are so many easy ways to do simple mods to personalize it. :D
1 Jul 2011
Has there been any update on when these will be available?
I only ask as Phanteks themselves aren't shipping to customers till the 18th.
That is for Phanteks USA based in California,USA. The containers coming from China going to California are on a different shipping route than those coming to Europe and UK.
I know that's not much help but it's the best I can give.
1 Jul 2011
Came up with these renditions of what 4x 40mm, 6x 40mm and 10x 40mm caster bases will look like. Think I prefer the 6x caster. :confused:
