Mmm shiny... Looking forward to seeing more progress on this!
are you only having 2 sticks of RAM? if you are make sure to use the colour coded slots in order to benefit from the dual channel speeds
Looking really nice.
I have to ask what the hell's up with a rad that doesn't come with g1/4 caps for the unused ports? Poor show there...
Then again, I've got a couple of AX360's and they only come with the bare minimum of screws, so I shouldn't be too surprised at XSPC
Btw, you don't need to be too concerned about having constant access to the speed dial on the D5. Just set it at 2-4 and be done
Love the rad flushing.
+1. It is a novel idea. Surely you used distilled water afterwards? Isn't that the normal process?
That is not as bad as some. Kudos.
Gutted on the 290X. I guess that is a potential problem of buying with the block already attached. Surely OCUK should have tested the 290X before they added the block? Maybe they should introduce that to their QA process otherwise it means huge inconvenience for customers.
Good luck
