Replacement heated windscreen issues.
9 Dec 2009
Bristol
Well, here we are again & another failed screen. First time using it tins winter and there was a 3" band down the passenger side not working so they replaced it last week with another "Shatterprufe" screen and now it looks like a barcode, it's worse than the one they just took out!
You could demand that an OEM one is fitted, I think the glass provider will try and pass the extra cost onto the insurer. I used to work for an insurance broker and we occasionally had a customer demanding OEM glass rather than the windscreen company's "like for like" replacement. The majority of the time the insurer did agree for OEM glass to be used.
The insurer is regulated by FOS so you could threaten to go down this route if they don't facilitate a resolution to your windscreen woes by agreeing to an OEM replacement.
OP
7 Dec 2002
UK
St220 here also (not to far down the road from you if i am correct (Warsop)), i ended up paying extra to get a ford one fitted independently (auto windscreens) cost about £400 from memory been fine although now has chip in it. Went through 3 aftermarket ones first mind.
Was this Autoglass fitting the screens and was yours repeated heating element failure?
If so how long ago was it and can you remember what glass they fitted?
They deny there are any issues with their glass but you are now the 3rd person i've spoken to who has been through the same thing.
OP
7 Dec 2002
UK
This is the eventual plan but i'd rather not go there due to the hassle, i have a complaint raised currently with them.
One of their engineers called me yesterday & is trying to blame it on a faulty alternator, it's been checked, it's fine. He told me that the replacement glass costs them over £500 each time so they want my car to check over it themselves, thought he was talking tosh so rung my insurer & got a copy of how much they were billed for the glass and it was only £158.94 so with my £75 excess £233.94 and they will be making a chunk on that so i bet it's less than £200 all in.
18 Oct 2002
Was this Autoglass fitting the screens and was yours repeated heating element failure? Yes was autoglass (but had similar in my old Mk2 mondeo and that was from National Windscreens none of them seem up to the job.)
If so how long ago was it and can you remember what glass they fitted? Cant remember what was fitted it was about 2 years ago happened early November and by late March i was on my 3rd one, first one lost about a 3inch strip on the drivers side, second one cracked on a very cold morning after being turned on and the 3rd one lost a strip on the passenger side, just got fed up of messing a round in the end.
OP
7 Dec 2002
UK
If it was indeed Autoglass would you mind me quoting your vehicle reg as an example? Do you still have the car?
Yes i'm not far from you, i'm in Worksop.
They insist there is no issue and there clearly is, it's not something i'm willing to back down on. The only acceptable resolution now is a dealer screen fitted to proper Ford spec, if there is no Ford logo on it it's not acceptable.
10 Jul 2008
Does your screen have to be "damaged" for you to make a claim on insurance or can you ask for replacement even if just an element breaks? My ford has a failed section. I'm fully comp and replacement screens are about £75 or £100 excess for me I think.
OP
7 Dec 2002
UK
Normally they need to be damaged however all the replacements are failing and are under warranty.
10 May 2024
England
Hello, I'm going through the same thing. Had a damaged, heated windscreen replace via insurers who use Autoglass. Got a South African brand windscreen. First damp day with condensation and the heated screen doesn't work. Called to complain, they are admittedly going to send out another tech to inspect, but it's a wait all day appointment.
I can see no elements in the screen and it does not work. Autoglass apparently could not cross reference the part number and brand printed on the screen to tell me if it is a mistake and the wrong screen, and state screens don't need the elements to be heated?
My car is a Jaguar s type 2005. This is the brand and number of the fitted screen.. can anyone out there tell me if it's heated?
Sahatterprufe E11 laminated 43 R-00087 DOT 122 M39 AS1
8 Mar 2024
UK
I guess the frequency of which Autoglass (and similar) are fitting heated windscreens is now becoming less and less.
OP - very nice example of your car though. Looks immaculate.
Man of Honour
21 Nov 2004
Anyone else had a heated windscreen replaced and had nothing but issues with it?
I have Autoglass coming out tomorrow to fit the 4th windscreen in 12 months to my car as the heating elements keep failing in the ones they are fitting, last one was fitted only 2 months ago.
Anyone else had the same problems?
Yes, the heated elements and auto wipers never worked again.
OP
7 Dec 2002
UK
Ah, this thread! Pulled ye olde ST220 out of storage for another summer. Warmed it up, A/C still icy cold however i have failed elements again, another new screen incoming!
