Replacement motherboard.
20 Jun 2023
uk
Evening. I currently have an Asrock B760m motherboard. In my wisdom I thought dropping it was a good idea after cleaning and starting to reassemble everything.
Yes, I know.
So now due to a bent pin or two it won't boot.
Can anyone recommend something similar for say £100?
Thank you!
Man of Honour
23 Mar 2011
West Side
I'm not sure, it had a good smack.
Intel i5 13400.
While the Asrock is a good budget board I personally would want better vrm cooling if planning to get a more powerful CPU in the future.
If you don't mind spending an extra £20 the
MSI Intel PRO B760-P DDR4 II is a good choice .​
Is your Asrock motherboard matx or atx ?
