Thanks tamzzy.If there's no added cost to getting the 5kw inverter in comparison to the 3.6kw inverter then that's a no-brainer
I'll have that then.
What about the price is it about right?
i'm using my own quote as comparisonThanks tamzzy.
There is shading on both roof faces from local trees. It sounds as it is a good ask to have these internally mounted to assist in maintenance should one fail.Why have they quoted for optimisers if you don’t have issues with shading?
What ever you do with on batteries, the key things to look out for is:
Max charge/discharge rates - this may we’ll be lower than the inverter power and varies by battery model, even from the same manufacturer.
Depth of discharge - this is how much of the battery is usable. Some market their battery as the usable capacity or 100% DoD, others market the gross capacity which and an 80% depth of discharge. As above, it’s not necessarily even consistent from the same brand, check each quote carefully.
Oh damn.The 5Kw givenergy inverter can only output 3600w from the battery, no point going for that if its the extra discharge you want.
Thanks for this,.The 5Kw givenergy inverter can only output 3600w from the battery, no point going for that if its the extra discharge you want.
Thanks so much.Inverters are more efficient closer to capacity than running at a low % level.
Its partly one of the reasons people overpanel as it means the inverter will be running in the more efficient part of its curve more often.
It will yeah, but really I agree with MKW above.Thanks for this,.
Will it output at 5kw if from both solar and battery?
Thank you so much.It will yeah, but really I agree with MKW above.
Depends on what the cost benefit is ultimately. While your argument is correct, those appliances are running for 2 mins tops to the grid in terms of KWH is very small.He'd be better off ditching the givenergy inverter for a brand that can output the 5kw's imo
A 3.6kw inverter in the home is brainless imo, turn some high draw appliances on and no matter what the solar or battery's are doing you will be drawing from the grid what's the point in that?
Boil your kettle while sticking some toast on that's 4kw alone
Since having the intelligent octopus tariff we load shift all dishwashing, washing machine use to the cheaper overnight also.i don't think i've ever gone over 3.6kw peak in the last ~2 months i've had my pv system...but i have to admit i've changed my use behavious as a result of having the pv system, and now i stagger my high power appliances to stop the spikes
it isn't expensive, and probably cheaper than averageAnyone else comment on the price please.
Hate to tell him yes and then find out it's too expensive.
Thanks Tamzy and everyone else for helping me very much appreciated.it isn't expensive, and probably cheaper than average
my installers were a company called Spectra Solar up in Wigan, but they do installations in the Midlands too (I live in Brum)
get a quote off them if you want to compare
i can fully recommend Spectra, if you do decide to go with them as well
I'll look Spectra up.
@Ace Modder company called Spectra Solar
They're based in Wigan but fit all over the country (I live in Brum)
Top class service and can totally recommend, no salesmen, no pitches, no nagging phone calls as well
They're coming back in a few weeks to fit another Sunsynk L5.1 Battery for me all for £1450 fitted
