Solid State Drives (SSD's) explained
19 Dec 2005
Perth, Western Australia
Hi lads,
Looking at 2 ssd but unsure as to which is better
Crucial 64GB 2.5" M225 SATAII Solid State Drive Mfr#: CT64M225 about €160
Or
Intel 80GB X25-M SATAII 2.5" MLC Mfr#: SSDSA2MH080G2R5 about €190
Now price is close so thats not an issue
OP
28 Jan 2007
Manchester
If anyone wants to update the info in 1st post feel free, as there's loads of new drives and controllers out. I haven't been following SSD's since i made this guide, so i have only updated some of the information, some information may be incorrect such as raid capability of newer controllers, but overall it is mainly correct.
The best 60-80GB SSD's to get now are the Sandforce F-100 controller-based drives, ocuk's cheapest is the OCZ Vertex 2E which is £150.
EDIT: please can a Moderator delete posts, 6, 25-28,31,34,35,45,46,48 as they are no longer relevant and will confuse new readers due to better drives now being available and drives they are talking about are no longer in post 1, thanks. Once done please edit this request out of this post so that other moderators don't delete new posts.
Thanks.
20 Jun 2010
Leeds
Hey,
Just have a quick question. I have received my Intel X25-V 40GB SSD and Im planning to install my Windows 7 onto it. Was just wondering what are the first steps I must take to install this, does it require an update before I install windows or can I just 'Plug & Play'
Bear in mind that this is a new system build that Im working on at the minute, all the parts are brand new
Thanks Hope someone can help
Tomm
Man of Honour
4 Jul 2008
Hey,
Tomm
Plug and play mainly, but you change it to AHCI in BIOS before you install
By the way, props to the OP - very useful thread.
6 May 2003
stoke on trent
ive just had 2x OCZ Vertex 30GB and put them in raid 0.
now im reading that raid 0 wont allow trim command but when i run fsutil behavior query DisableDeleteNotify it returns 0, and if i understand correctly means that trim in enabled.
is this right ?
ga-x48-ds5 mobo
14 Aug 2010
brilliant thread.
quick question....
i'm looking for a cheap ssd. sub 100quid. although if there's something a tenner more which is a lot better i would get it. Any suggestions?
OP
28 Jan 2007
Manchester
recomended drives are at the end of the original post.
MODERATORS: please can you delete posts, 6, 25-28,31,34,35,45,46,48 as they are no longer relevant and will confuse new readers due to better drives now being available and drives they are talking about are no longer in post 1.
Thanks.
Man of Honour
29 Jun 2003
Wiltshire
A quick heads on up how to increase SSD drive performance, for those that have had them for a while.
http://www.ocztechnologyforum.com/f...-A-simple-guide-for-speeding-up-EOL-OCZ-SSD-s
I just followed the guide and it has improved my OCZ Summit (which has TRIM) speeds a touch. It took about 30mins to consolidate the space and 10-15mins to write over the free space.
