Unigine Heaven 4 benchmark
6 Aug 2009
Wales
quick run
Hiya nick,
Just a quick question, are you using a lower textures filtering quality in the control center and is this score at the stated clocks in your sig?
I get around 53fps on my gigabyte 7970 ghz that's at 1200/1650:confused:
Either somethings not right my end or your cpu is making an awesome difference.
22 May 2007
Hiya nick,
I think its your CPU mate, I had a look at your 3D Mark 13 score in the official 3D Mark 13 thread and your psychics score is way down with an overall score of 6094 yet your GPU score is 8582 whereas mine is 8282 but overall of 7239 because of my CPU.
9 Apr 2010
All settings on max.
1920x1080 with 3x 7970's
Blimey Stu I would have expected higher with 3x7970, its only 13fps more than 2x7950 ????
Stock clocks?
and here's mine in comparison to yours my 7950 vs your 7970 both overclocked not bad considering mine cost £ 188 ex VAT and yours is £ 416 ex VAT!
Try again with 8x AA and Extreme Tesselation like the extreme mode preset sets
quick run
As above :)
15 May 2012
Louth, lincs
Hiya nick,
no not updated sig, gpu was @1240/1850 and [email protected]/ram2.4 tunned, apologies for the confusion
6 Aug 2009
Wales
Cheers niel,
The plan was to switch to an I5 this month but due to some Muppet plumber breaking my combi that's not going to happen now :(
Surely that overclock compared to mine wouldn't net you almost 8fps more than me though would it?
I was under the impression that heaven doesn't really use the cpu or ram?
or at least not that even to make a huge different to scores, it is after all a GPU Benchmark.
I really need to sort out swapping over to intel if that's not the case:(
Great score btw though:D
Edit-Just seen your score at my clocks above :), it seems it does!:D
