What's your wireless SSID?
  • Thread starter Deleted member 651465
  • Start date
12 Nov 2015
How would the name have any bearing on how hackable the wifi is? :confused:
Mine is my last name backwards. Makes a decent random word that is recognisable, but not guessable.
A decent article on how the SSID relates to the decryption key here:
http://www.tomshardware.co.uk/wireless-security-hack,review-32252-5.html
There are two major parts to converting a password value to a decryption key. The first is called salting. It's possible you've heard this term used once or twice. This is a method in cryptography that prevents two systems from using the same key, even though they may share the same password. Without salting, a pair of machines using the same password, even coincidentally, end up with the same key. This is a vulnerability for rainbow tables,
Using non unique SSID's is generally bad practice, especially if combined with short, Low entropy/non random pre shared keys. While we're at it I'd avoid using a SSID that identifies the make/model of router.
That said "Abraham Linksys" is more fun than "8RP8c<&/z7'23bz80D2{" :)
29 Apr 2004
Bath
Mine is Ankh. All of my devices and wifi networks use names from the Freespace 2 ship database. Laptop is called Mara, Chromecast Ultra is called Hele etc.
