White Out
OP
6 Aug 2010
Suffolk
As much as i'd love a white PCB graphics card, due to currently having a 780GTX i'm only going to buy an additional one to go with the build...
On that note i had another delivery from OcUK today......
All parts have been brought now, all i need is the White Enthoo Primo!!! :D
12 Jan 2013
Gdansk, Poland
You know that you can remove that black faceplate from waterblock and paint/plastidip it white?
And you can add white LED instead of blue, or stay with blue to add some contrast, maybe?
Looks good tho :)
OP
6 Aug 2010
Suffolk
I will be adding white LED's to blocks, and i have thought about plastidip coating the metal parts white i think it's something i might consider when I've seen how it looks it all together!
12 Jan 2013
Gdansk, Poland
I am still considering.
Let me know by the way if you decide to paint anything white.
I bought some MTN paint at OCuk, but my build plans changed in the meantime and I am stuck with 5 cans of white spray which I don't need.
18 Oct 2002
Hereford
I'll happily take a can off you, unsure if they're 'on-topic' on the MM though? Trust me if not, create a thread if so! :)
Any pics of your sleeving yet MorleySA? I've just about finished my Hale, will take some pics when finished this weekend... Really took my time which hopefully shows! lol ;) :D
OP
6 Aug 2010
Suffolk
Where did you get your sleeving from Roady?
I've ordered some more, silly i didn't order enough last time round! will post pictures of all of it once i'm finished!
OP
6 Aug 2010
Suffolk
Another update, i started sleeving some cables today, my progress so far......
*^* D5 Pump before i sleeved the cables
*^* After shot, with a black Molex connector and Fan header
*^* Tried to make this as neat as possible, this end will be hidden in the Monsoon Bay/Res anyway.
*^* My 1st attempt!
*^* Not sure this is neat enough....
*^* CPU 8-Pin power cable
*^* Close up
*^* SATA Connector, before and after shots
