What on earth are you on about?
Chip manufacturers moved to multi core because of the inability to increase clock speeds, that is the performance of a single core, performance of single threaded applications is reduced on multi core systems and many pieces of software cannot be multi threaded well resulting in a higher speed single core cpu performing much faster than a multi core cpu with a total higher clock speed. Eg 1x8GHz vs 4x4GHz, as per Amdahl's law.
Again, not really, look at Superpi on a Core 2 architecture, 4 issue core, which is wider than their older cores, Superpi fills it, a few other benchmarks do, 99% of real world applications DO NOT fill it. Its inefficient, most instructions are broken down into VERY simple pieces, this is how it HAS to work. You could have a MUCH faster single core, that was 8 issues wide, however, you'd just be increasing the unused part of the core as your application still only averages 2 issues per clock, if its a 2 issue core, or a 85 issue core, the only difference would be increasing inefficiency.
8 2 issues cores will likely end up in most situations FAR more efficient than 4 4 issue cores.
Clock speed wasn't really the big deal, single cores really got as complex as they needed to be, the main thing required was more cores for other threads.
Almost no user in the world uses a single thread and wants 59Ghz of performance out of it, its pointless, inefficient and very difficult to do. Windows constantly does stuff in the background, at the moment I have a football stream going, firefox, IE, windows explorer, a game, a downloading application, the stream outputted to a VLC window.
Windows is smoother by having these things working on different cores on many threads, than on one core.
As has been discussed and shown in this very thread, Superpi is pointless, newer multithreaded versions are faster. Superpi, one application will be faster on the same architecture with a faster core, but on a multicore chip with better software, its much faster still.
The only reason a single core uber speed core would be better, is if you insist on clinging to decades old software that was writen for computers that ran Windows 95.
