X79 Overclocking Guide
Caporegime
12 Jul 2007
United Kingdom
What does clock gen filter do? When i used it previously at lower clocks it seemed to lower my core clock speed under load. In the bios it says it will help reach a max overclock, but I've always kept it disabled because of the issue i mentioned.
1 May 2014
Managed to get 2000mhz stable on 125 strap 8pack but my vccsa is at 1.90v timings are 9-11-10-24 2T tried 1T n it failed would like to know how to get 4.4ghz on CPU using 125 strap ATM its at 4ghz and Turbo mode is disabled so I was hoping windows would see 4ghz but it never CPU z sees it.reason I mentioned this is on a non cap BIOS there was a feature to allow non Turbo frequancy to say 4ghz on CPU and if I tweaked the bclk a bit it would show the said speed in windows info.I'd like 2000mhz ram and 4.4ghz CPU but I don't know how to configure it so Turbo mode ends up disabled like I said it disables at 4ghz and 2000mhz ram ram volts ATM are 1.665v like you said to try ATM all is good just need your help to also see if I can squeeze more out of ram speed cheers 8pack Crasher
1 May 2014
Hi 8pack right I'm at 1966mhz @9-11-10-21(Samsung ic? Tras21)1.665v on dimms with 1404.rom bios on BIOS chip 2.vcssa @ 1.130v(testing now memtest )was at 1.85v passing each time I've dropped it lower. Turbo disabled Ht off.CPU bclk at 122.875 strap at 125 passing memtest no problems and super pi also Intel burn test on standard and high 16 runs time premium due to kids LOL now heres the kicker I input all my settings on to bios chip 1 which is running 4901.cap latest BIOS and low an behold it fails memtest but stable again on BIOS chip 2(confused.com )now here's another kicker when memtest starts with multi thread enabled F2 option it fails within 2 mins of starting I'm stable in windows at moment.so dunno what's going on oh in system properties CPU is at 3.93ghz. As I said in another post some reason a non cap BIOS allows for windows to see CPU oc and also if I set CL to 8 system boots but loses 16384mb of ram out of 32gb on my R4e and I'm also seem to get memory related errors like cmd.exe has failed to start when I shutdown system hope this makes sense 8pack. Get bk to me as soon as u can mate really need some tips Crasher
1 May 2014
Also had 4 beeps at save and exit on BIOS 1404.rom 8pack so after it booted I loaded a saved 1966mhz ram profile and all is good again tbh think I'm gonna give up with ram ocing and just try to tighten/optimize timing on stock 1866mhz cus no one getting back to me yet so ill stay stock until you get back to me with some ideas and settings to try mate crasher
14 Apr 2011
Newark
Just had a play around with my 3930K, got it running 4.6 with 1.34v and temps in the mid 60s with a H100i. Can't seem to get the voltages down any further. Is this a decent chip. Might have a go later at 4.8 .
19 Oct 2004
London
Very good I would say. Where are you getting the 1.34 from? Mine says something similar in CPU-z but because of the dynamic vid in offset mode I'm actually at 1.43 in the bios.
14 Apr 2011
Newark
Yes, using Cpuz for the voltage reading. But if I go into the bios, my reading is 1.18v, which is round about my idle speed not full load.
18 Dec 2008
Liverpool
Hi guys, I'm a complete noob to overclocking and have absolutely no idea what I'm doing but want to give my CPU a stable overclock.
I'm using a 3930k on an ASUS x79 Sabertooth board with Samsung Green 16GB (4x4GB) DDR3 PC3-12800C11 1600MHz 30nm Dual Channel Kit. Is there a list of recommended settings for me(or a complete idiots guide to overclocking) to change or should I just try and match the settings in the OP?
30 Jul 2014
Hi all! after 4 years of silence i'm going to talk about this old platform, i'm user of a 4930k and Gigabyte X79-UD3 with 12 Gb of Ram
Yesterday, trying to cross 4.4 Ghz barrier searching info i found a youtube video about overclock on X79, in that video modify vcore (obvious) VTT, PLL and VCCSA(IMC on gigaybe), that three last voltages i don't up too much afraid to broken the cpu, but i copied his settings.
And i manage to boot in windows and doing various benchs at 4.5 Ghz at 1.308v, Ram at 2133 11-11-11-34-2t, PLL 1.865v, VTT 1.165v VCCSA/IMC 1.05v, then i tried 4.6 ghz with same vcore, booting windows OK, cinebench OK, cpu-z OK, some minutes of prime OK, but when i restart all stability gone, freezes in blue reboot screen, very difficult to have video and enter BIOS, when i have video and enter windows again all is working fine, but at restart all is gone, at 4.5 Ghz is always perfect, but at 4.6 Ghz no, i tried with vcore at 1.38v, nothing, downclock ram to 1333, nothing, VTT 1.25v and VCCSA/IMC 1.15v nothing, i don't know how can i try to get the 4.6 ghz oc stable.
Before yesterday 4.4 Ghz at 1.30v was my max OC, 4.5 Ghz even with 1.45v was 100% unstable
I have custom water loop, max temp around 52-56º that isn't problem
Any idea?
Regards
Sorry if something is writen bad or strange, i'm spanish :)
Man of Honour
13 Oct 2006
Gigabyte X79-UD3
I have the 1.1 revision of that board and TBH there are a few little issues in getting it stable with certain frequencies - it doesn't like my RAM at 2400MHz at all (seems to be some firmware bug not just my IMC struggling) and some combinations of settings just seem unstable whatever.
Also possible your CPU has hit a wall - most go upto a certain point OK then are progressively harder to get even a tiny bit more out of them.
30 Jul 2014
Maybe the wall is 4.5 Ghz, but is strange, when boot up it run perfect at 4.6 Ghz, but at restart bye all stability... between 4.5 and 4.6 the only change is the turbo cpu multiplier, 45 to 46, maybe should i try without turbo? or fixed vcore instead offset?my MB is rev 1.1 too and F16 bios
EDIT: for now 4.4 Ghz at only 1.18v, in next days i will try higher oc
9 May 2007
Microcode 0x42c and 0x42d braking overclock's? 4930k microcode 0x42d is from this modded bios https://rog.asus.com/forum/printthread.php?t=72562&pp=10&page=1 Windows 10 WHQL RIVBE driver pack
Updated BIOS with:
(Meltdown and Spectre mitigation updates)
-CPU Microcode 0306E4 IVB-E - 42D
-CPU Microcode 0206D7 SNB-E - 714
-CPU Microcode 0206D6 SNB-E - 61D
-Updated NVMe BIOS driver
See bottom of page 10 for 4930k
https://www.intel.com/content/dam/www/public/us/en/documents/sa00115-microcode-update-guidance.pdf
9 May 2007
@sonic AFB Whats your CPU voltage frequency. 4.5Ghz I can get 8k FFT stable at very low vcore but 4096K FFT takes lots of vcore to be stable. It could be that you are unstable at your settings. 4.4Ghz at vcore 1.18volts is a lot better than mine.
