I put a blob in the middle about 4mm across, stretch a bit of plastic bag across my finger, and use that to spread the AC very thinly across the whole surface of the CPU. This works very well![]()
There's a nice picture on the following thread in post number 4 of some AS5 applied to a quad -->
http://www.sharkyforums.com/showthread.php?t=300298
But I guess - if the heat spreader is slightly concave, spreading the paste out in this way is surely not the best way ? The "blob in the middle" and then putting the heatsink straight on on would allow it to fill in the concave bit and achieve better heat transfer ?
I've never come across a CPU with a spreader all that concave or convex for that matter, and even if they were slightly out they wouldn't be by more than fractions of a mm, would they? Even pre-spreading the goo, either with a finger or a blade, the heat and pressure would redistribute the paste to fill in any large-scale defects like that, but you could end up with hot-spots through uneven paste distribution anyway. Pre-spreading just limits the amount of goo you use in the first place so /should/ reduce temps marginally, defects or not.
