- 12 Jun 2006
So everything came today and i started building my pc.This is my first complete build and my 1st time watercooling.It took me about 6 hours to place everything.From the watercooling kit I have only installed the cpu waterblock (by the way the kit is the one that comes with Tt's Armor LCS).All I have to do now is place the pump+reservoir and the tubes,but I am too tired to do it today.
Anyway,I raised up the case and I looked it,and I noticed that the cpu waterblock,instead of beeing in a horizontical position(as shown is the case's manual)it is vertically fitted(the holes in which the tubes go are in vertical position).DAMN.Do I have to rotate the waterblock?Inside the waterblock I can see some kind of a zig zag starting from one hole and ending at the other one,which probably means that the fluid wont "move"correctly,right?I dont know if I make any sense,I am tired and dissapointed because rotating the waterblock without removing the mobo from the case(and the rest of the hardware)will be a pain.So do I have to rotate it?
