Hi,
I've got my Plasma TV mounted on the wall, but the problem here is that the cables run down the wall (currently) and I need to tidy them. What are the best options? Chasing the cables in to the wall is not an option.
The walls in the room are a chocolate colour at the bottom, and a lighter brown at the top, seperated by dado railing of which the TV sits about 5 inches above. Obviously due to these colours I don't want white trunking running down the wall. So really, what options have I got?
.  The metal I linked to should (I haven't tried it yet) take a scart cable if you get the largest 38-57mm size.  I have the intention of using this with my setup after the loft has been completed as my monitor is 90 degrees to the dvd player etc and I don't want send the wires via the walls
