Demand for sub £100 PC?
Yes but the main problem is, the primary market won't be able to find the equivilents, therefore it's a bit pointless.
Burnsy
Yeh, in a way i agree, but there are lists around stating equivilant software here. It would probably be best to pre-install basic software, OO, xmms etc.
Although £99 seems good, by the time you buy a monitor, kb, mouse, the price is much more than the £99 it first seems. You also need to learn a new OS
Most people would probably just buy a £300 all-in PC from the high street.
It seems like a good idea, but i can't think of many advantages this has over just a normal PC. Could be good as a spare/backup pc?
That's the thing though... A ton of people already have an old PC (with monitor and peripherals) and just want to update their base unit...
Obviously it's not for everyone, but then nothing is
I would say there IS a market for a £99 computer, provided it is all setup and pre-installed.
So when the customer opens the box and turns it on, it will boot into something that looks very much like windows, has software that looks very much like Microsoft Office, and can connect to a dhcp router, or use wireless and get onto the Internet in much the same way as if they were using windows.
Yes exactly, it would do all those things.
AND it would be in a nice black enclosure :p
Ok.. next step Mr Jobsworth wants to install a Printer on his PC to print off his kiddies school reports, how easy is this to do without having to scour the web for suitable linux drivers?
As far as I know most the leading printer manufacturers offer Linux drivers just like Windows?
As you say, having a 99 for the base unit, and perhaps a 199 for a complete set?
Linux is deffo the way forward, and also it can give a life to an old spec pc...
my mistake, just checked the email i had of the deal and it's £149
Got the email thanks!
One BIG difference is that you have to build that PC yourself. They basically just supply the raw components...
Considering most PC techs will charge £30+ to put a system together, £99 for everything is quite a bargain :p
I don't think Linux support would be terrible if you went about it the right way. Plus I think a lot of people buying the PC would only be using it for basic tasks anyway
Thing is those same people will be great a screwing an OS up and I've never used Linux but I imagine a screwed up linux installation would be harder to fix and diagnose than a windows one?
It would be pre-installed with the system, so there would be nothing to screw up in that regard
You could easily offer an "upgrade package" of a monitor, mouse, keyboard, and speakers for under £70. Easily.
n00bs can't mess as a pre-installed OS up clicking things they don't, accidently deleting files and so on?
Well yes... Anyone can mess up anything in theory.
If they want support then they'll have to pay for it (as with every other PC manufacturer).
Dell have already started offering Linux on their PCs, so it can't be all that bad.
Also having Linux as the installed OS would be completely optional. If the customer wanted (or already had) Windows, that would be fine too
Brilliant idea. You would struggle to make a profit at £99 though unless you where selling a lot.
Thank you, and yes you are totally right about the struggle for profit.
Margin is extremely thin, but you could make additional profit on upgrades, and also by what software you install on the PC itself (for example Firefox).
Lack of profit is probably the main reason why no one has done this yet
