How do i find my own posts now?
6 Oct 2004
Behind you!
I'm sorry if this has been covered but it's driving me nuts. How do I view posts I've made? Before the great change it was easy, click on usercp and there it was... that option has now gone. Can someone PLEASE tell me where this essential feature has hidden itself.
Much appreciated :)
Thats fine if I'm already viewing a post by myself... but assuming I'm starting from scratch... how am I going to find a post by myself to do that with?
Scroll to the active users at the bottom of the forum index and click your username, then click view all posts.
There should be a link in your profile. One will go to your posts. (Also there is another link [hence I said "One" before] which goes to threads created by you).
[Link]
That is the link though.
Angus Higgins
Appreciate your reply but I don't get it. I don't see any link in my profofile... or perhaps I dont know how to get to my profile. either way the link you gave me is:
vBulletin Message
Sorry - no matches. Please try some different terms.
vBulletin Message
Click on your name on the left above your avatar, then view public profile, then when you see your profile click on find all posts.
What?
It is simple I believe.
Have you tried the "Quick Links" > "My Profile" > "Find all posts by " + [Insert Username Here]?
Angus Higgins
Finally, a sensible answer. It's not as good as the old system, but it's better than the people in this thread who suggest I "search" my name name every time, lol.
Thanks for helping!
