360 Gamepad Accessories
12 Oct 2006
Tatooine
So what do people use?
Quick Charge Cradle and packs?
Play and Charge Kit? How do they work?
Or some really good rechargeable batteries and charger
What do you recommend?
Rechargeable batteries (2700mah ones) and a sprint 20 minute charger. They last 2.5-3 times as long as the play and charge kits.
Play and charge kit that's plugged into my PC. when I walk away from the 360 I just plug it in, keeps it charged no problem. No messing around changing batteries.
My PC won't charge a play and charge for some reason, the light goes red, then turns off :( Yet it'll power a bus powered drive. It used to work though!
I use a quick charge kit and 2 packs on rotation. I have spare rechargeable batteries on hand since I use them in my mouse and Wii controllers. Hardly ever change to the batteries unless I am playing 2 player.
hmm didnt know that the plug and play would work with a pc. means when i switch off the xbox it wont stay on standby mode humming :)
Energizer rechargables....got 2 chargers both taking 4 batteries each and plenty of batteries ...(use them for mouse n keyboard as well)
and they last for ages :D
Play & Charge kit.
You get a rechargeable battery & USB cable with it. The cable attaches to the top of the controller to charge it.
What are the best rechargable batteries and chargers, and where can you buy them ?
Had a look aroun a few shops, but i know nothing about them.
