What a NUB.. Love the part about if you have a faulty fan you might have to plug it into the 3pin chassis connector, rather than the 4pin cpu fan... Guess the nub doesnt realise that modern motherboards can shut the fan off completely until needed.
And his thermal paste.. eeew
When you install the motherboard onto the standoffs, and install the RAM, CPU and heatsink - you're sometimes using a lot of pressure, for the RAM or heatsink.
When applying downwards pressure on a motherboard mounted by only 6-8 screws, then the motherboard is almost certain to flex. If a motherboard flexes too far, the circuit tracks in the motherboard could fracture - and remember that some circuit boards can have upto 4-6 layers.
Where possible, it's best to install items in the motherboard on a flat surface. If not to ease the pressure on the brass/plastic standoffs, but to prevent damage to your motherboard.![]()
I wouldent think his E6300 would actually run cool enough that the fan dont even need to spin up with that thermal paste tho, let alone the stock cooler.
His thermal paste application looks identical to a video he posted a few months back, just seems to have removed the hsf a few times since then, that paste looks like someone took a dump on the cpu from a few feet.
Is it that hard to follow instructions that are available online with very little searching? Youd think by now with the amount of people telling him he hasn't a clue about applying paste he'd go and check it out.
Can't believe he had all the components laid out on the carpet, he must like to take risks with his hardware. Just waiting to see him do a guide to overclocking. "Just keep rasing the FSB til there is a nice red glow coming from the cooler".
He's still no Rodney from 3dgameman.
lol
did you see the thermal paste on the cpu?
Well this was Jacob Billings very first attempt so he's come on a bit - http://homepage.ntlworld.com/ashen1/ashen/menu/build/intro.htm
Blatantly stole from another thread.
