Installed my Thermalright Ultra 120 Extreme but...
29 Apr 2007
Teesside Uni
where are the other two 12cm Fan Wire Clips
I had two 12cm fans on my old Noctua NH-U12F CPU Cooler which came with four Wire Clips and I've read reviews on the Ultra 120 extreme with dual fans so I thought it would come with more clips...but no...do I buy them on there own somewhere?
Cheers
Just found the same thing with my new TRU 120 Extreme - even with more fan clips you wouldnt be able to fit them on anyway? (The holes are already occupied by the first fan clips). might just see if I can cable tie a second fan on or something
i saw a picture somewhere where they used one clip per fan. as already stated, another pair won;t help you as there is nowhere to install them.
There is a 1-2c gain by adding another fan if you wish to do so try usin tie wraps...from fan to fan.
Had fairly better results with 2 Nexus orange at 7v on my 120 Ultra (not extreme), @ load and single fan at 12v my E6600 @ 3.6Ghz 1.375v hit 67C max in TAT on a warm day, with the two @ 7v it hit 64C tops and was significantly quieter, could be the case used though which was a Antec P180. Used a rubberband btw :D
May be revision, original were dodgy, USA peeps had to stick cardboard or coins in centre to get a tight mount, some came with nylon washer some did not.
WJA96 email sent.
I have two Noctua NF-S12 1200RPM 120mm from my old Noctua so I really like to use both fans rather then just wasting one sat in my draw.
Cheers guys! :)
If you find somewhere you can get fan clips from let me know please ;) I'm in the same situation as you, 2 Noctua NF-S12 1200RPM 120mm's from my old Noctua :p
Found a UK online retailer who sells them but out of stock atm, but I emailed thermlright and they are sending me some...altho I did say it came with none lololol email me and ill help you out.
