- 4 Jan 2004
- ¯\_(ツ)_/¯
As you can see, this wheel has seen better days.
Sooo.... I plan on satin black. Now, what prep work should I do?
I was gonna clean off the brake dust first, and maybe use a bit of wet and dry paper on the bits where it is not smooth... then spray the new paint over the old paint.
Is this ok, or will the paint flake off or something? What's the best way of doing this?
  Thanks for the tips, hopefully it should go to plan!
