Yes it took me over a month to get mine?apparently asus sometimes offer a free fan but not always, and they can take a while.
good stuffi fitted the Northbridge Cooler
yeah it works well. I tested it running *passive* and the system was stable etc but when I felt how hot the blue zalman heatsink was I decided to position a 120mm Sharkoon 1000 fan over it suspended on a Zalman fan bracket.i couldnt be happier with the fan-less cooler now, my pc is soo much quiter its unreal, thanks for all the help![]()
@ the person who asked if the fan went, yeh it would randomly not work, id have to keep re booting the pc or open it up and give it a nudge to get it started.
I might be installing one the next couple of days so I'll try and get some snaps. For the record the Thermalright heatsink fits fine on the A8N-E although the SLI version gives you scope for a dual-slot graphics card.Has anyone got a picture of the Thermalright HR-05 installed on a ASUS A8N-E or similar motherboard? And how cool does this thing keep the chipset?
