Yeah pretty much the same for me as well. Surely the rig in your sig can handle Bioshock with ease, it scales very well. It's worth playing for just the voice acting, simply brilliant.
Works fine, im running the game maxed on DX9 mode, smooth and ace.
He's after 60+ though, no chance with a 7600 GT, i only get 50+ with a GTS.
I heard something about AA not working properly in Bioshock so you might want to disable that seeing as you only have a 7600GT. Maybe consider overclocking your cpu a bit further as this may provide a further gain if you drop to 800x600.
But then its appaling to look at.... maybe I'll try medium quailty with these settings
I tried those drivers but there was no improvement
Turn off some of the shader options.
If it can run Bioshock, buy it - the game is so good that you won't really care once you get into it IMO![]()
