Just got back from the store with my bro, picked up a copy of Madden 08, some new features on it judging by the back of the box ie you can now order the NFL champ ring..all new read and react system, new better hitstick and also now have the option of choosing NFL legends like Joe Montana, Walter Payton and Barry Sanders to name a few...also some new animations ie players reacting etc.
Havent had a chance to put it in for a play but will do later on tonight.
Clairvoyant BSC
If any one wants to add me
tbh guys i did'nt like it at all, did no-one else find it mind boggling to control? i mean you stop every 2 seconds anyway, looks good though, but then 360 games always do![]()
Yup im sure you can, not sure about 2v2 though but definitely play against each other on the same console but not as much fun as you can see which plays either one of you are picking..so can adjust your defences accordingly unless you change the play once your on the field ie on fly change.
You should be using the bluff feature to prevent them from seeing the play you pick: http://blogs.ign.com/EA_Madden/2007/08/13/63216/
Awesome gameBeen playing it today.
I suck atm, used to play the Madden games on the PC with a completely different pad, adjusting to the 360 one is strange. Great graphics, the animations are perfect.
Dan and darkcinder, at the moment ive added you guys but wont be able to partake in any games till i get back to the UK, which hopefully should be in another week or so.
Once i get back then we can have a few games if you guys fancy it.
