- 7 Feb 2004
I've had one of these for a month or so now, for those that don't know it's a new type of kettle that boils water in 3 seconds, there is a catch though, it takes about 30 seconds to pour.
You can also set it up so that it pours an exact amount to your cup size.
To fill it up you lift off the detachable container, they've done a good job and it's easy on or off.
For us it has worked really well, being much quicker to get a cuppa and it saves energy as it only heats up the exact amount of water you need.
There are a few disadvantages though, you would struggle to get a large amount of boiling water to help you with cooking say if you wanted to pour over boiled rice. There is a filter that says should be replaced every 6 weeks but I won't be replacing it anytime soon. The water doesn't come out boiling either but it is certainly hot enough and it just means you don't have to wait 5 minutes before you can attempt to start drinking it. It's also makes a bit of noise when it's going.
It's not cheap either at £60 although this would probably be offset against the energy saved.
We're definately pleased with it and already a few of our family and friends have bought one after seeing and using ours.
Best of all though it's another gadget and I'm a gadget freak
I've uploaded a video to see it in action, the cup being used might not look very big but it is bigger than the average mug.
http://www.youtube.com/watch?v=bAQXBQGkZ5c
*****EDIT***** PLEASE READ MY NEW POST FURTHER DOWN FOR A FOLLOW UP REVIEW
