Vista 32Bit Ultimate BSOD
1 May 2003
I loaded up my system, got to the logon screen, inputted my password, then I get the desktop screen, then it goes to the BSOD, and restarts. I put in the Vista disk and clicked on Repair my computer, but Windows reports that there is no problem??? I then try to do a restore, but I get the BSOD again. I cannot go in under safe mode as I get the BSOD again.
Here is the BSOD error I get every time
Is there anything else I can try???
You should have had a minidump of the blue screen saved to C:\Windows\Minidump. If possible and you have the facilities, I'd copy that file to a disk and load it up on another computer and use the Microsoft Debugging Tools for Windows to inspect the file and see what the caused of the blue screen is. If you can't though, I'd be happy to take a look at it and see what the problem is caused by if you can e-mail it (my e-mail is in trust).
Will try and locate it, thx.
