Crucial Ballistix 2GB (2x1GB) DDR2 PC2-5300C3 667MHz Dual Channel Kit (BL2KIT12864AA6
Obviously theirs no Guarantee's although they do use the D9 Micron chips which have great overclocking potential and i wouldn't be surprised if you saw overclocks of 1000MHz+.
Well I'm currently running my Ballistix PC2-5300 set at 1200mhz so I have to say they're great chips :)
I had a set of 5300, did 1200mhz 5,5,5,15 2.25vdimm (can't set to 2.2 on the P5B Deluxe) ...
ended up frying and now is in the process of being RMA'd....they received it last wednesday and I'm waiting to see what all the fuss about their fast RMAs is about!
eheheh
this ram overclocked and with 2.2V usualy last for 2/3 months and then die:D
they are great overclockers ,but do not last
after two dead kits ( at 2.25V) I learned the lesson,and now i´m using it at 1.9V ( at stock speed) in the past 3 months , with no one single problem (until now- touch wood:D)
eheheh
How far did you overclock your memory then mate?
I used that two dead kits mostly of the time at 900 mhz (fsb at 450x cpu mult. at 8)
but I tried one of the kit´s at 1260 mhz at 2.4V at 18-5-5-5 and it could do SP 1M at that speed:D
http://www.xt-pc.com/viewtopic.php?t=9627&postdays=0&postorder=asc&start=15
I guess maybe you got unlucky with your ram, I think there are plenty of other users running their ram 1000mhz + with no problems. I remember having a set of Balistix a while ago and I remember the key for keeping them from dying was good active cooling over the modules. ;)
I am quite sure that if you put those modules are anything higher than 2.1v they will fry if you are not using active cooling on them. I have mine on 2.1v and I am not planning on setting them any higher.
What speed is it you run yours at then?
Why is it then that Crucial rate them @ 2.2v on their own website that what I want to know . . .
What he said!
I think im at 2.1V atm.
Although im prepared to use up to 2.25V (but then again my mobo doesn't like anything > 511MHz so 492 @ 2.1 is all I got atm lol
Does 510mhz 4-4-4-12-4-30 @ 2.15V tho.
Probs do about 530/540 4-4-4-12.
Does 600 5-4-4-12-4-30, can't get it stable due to chipset :rolleyes::(
PC8500 btw 2GB
What he said!
PC8500 btw 2GB
Im tempted to try some of this bargain basement 5300 stuff and see what I can get it to for a laugh. From what I can tell the 5300 modules are the same as the 8500 stuff. Man I get bored to easy! :D:p:D
