No, he did a bad job. It's insecure as hell.
I shall justify, but in a less rude way as I did before, because rob's comment was just totally unnecessary, in my opinion.
what I did works, which was what the OP asked for. When I started out, I wanted people to explain things like this to me in a simple way because anything more than that can be quite overwhelming. I, maybe incorrectly, assumed that the OP is just starting out with PHP, and didn't want to confuse him with htmlspecialchars and the like, because they weren't related to what he was trying to do.
So, you're right - in the grand scheme of things, it wasn't a good job - but when do you see tutorials for this sort of thing using htmlspecialchars? You don't - for the very same reason that I didn't.
psyreen was correct (I never disputed this), you do need to make-safe the data because a lot of harmful things can be run from $_GET, so please don't use
solely what I posted if it's actually going online
however, I'd do this:
PHP:
foreach ($_GET as $param => $value) {
printf('<param name="%s" value="%s" />',htmlspecialchars($param),htmlspecialchars($value));
if that's still very insecure - for my edification I would appreciate the feedback, but I'd never do anymore than that in a real-world example. obviously, you could create a blocklist - but that would add complexity to the situation that the OP doesn't seem to be after at this stage
