- 19 Dec 2003
- UK
Hey folks!
So most of you would probably know, you can buy those hand sanitizers that you put a bit in your hands, then rub them til dry. Supposed to kill 99.9% of all bacteria etc!
They use it in Hospitals etc!
As I cycle to work, when I park up my bike I just spray a bit of purell a couple of times and rub it into my hands and away to work I go.
Is that the same as cleaning my hands? As in, can I still eat stuff etc!?
My hands still smelt of rubber from the handles I noticed! Even though i'd used that stuff.
