With high quality cabling and very good circuitry (OP-AMPS etc) it could be argued that an analogue connection is more desirable than a digital one. Digital connections invariably have to compress the RAW PCM audio to a more manageable bitrate, I think around 700KBps for Dolby Digital etc, however the good thing is that even using the cheapest nastiest digital cable its either going to be perfect or not work at all.
thats not true at all. it might be for HD formats, but as far as dvd is concerned spdif will pass the bitstream without alteration. dolby digital has a maximum bitrate of 640kbps btw
The bitstream will be compressed so that it can successfully be passed in serial form along either an SP-DIF or Co-Axial digital connection, both standards im sure will provide an upper maximum data throughput limit, which some hardware wll surpass but all will meet. In this case a throughput of 640kbps (as you quite rightly corrected me on) would appear to be the lowest common maximum throughput for all standards in all situations using the Dolby compression format.
All i was trying to point out was that on paper digital appears better in every situation, but in actuality a decent analogue setup *could* provide higher highs and lower lows due to the compression applied with digital formats.
Im sure the HDMI interface provides even more bandwidth, so this will eventually increase the standard bitrate, but a digital connection will always be truncated as it simply isnt possible to perfectly store a waveform due to the infinate numerical possibilities that can exist at any one point.
no it wont be compressed? its read from the dvd and passed stright through the sdpif interface, the pc doesnt do anything with it. in this case, there is no way to achieve a higher 'bitrate' with analogue.
that digital format is read straight form the dvd, so it makes no difference.
HDMI 1.3 has a single link bandwidth of 10.2gbps vs the ~9.2mbps of spdif. standard bitrates on dvd's will not change, its a feature set in stone of the various audio formats. new formats such as trueHD or DTS MA have huge bandwidth requirements (up to 24mbps for DTS MA) so obviously that cant be delivered over spdif at all.
regardless, this isnt about hd formats. its purely regarding dvd![]()
You know that dts / dolby digital sound is a compressed audio format on the dvd ?
he was talking about he audio being compressed so it can be transferred over the spdif interface- that isnt true
For gaming its....complicated lol.i've said this in another thread, the xfi's were king until vista dropped support for direct sound. now its openAL and thats what future games will all be supporting, making this whole EAX thing a non-issue.
Unless I'm mistaken EAX5 is supported via OpenAL on Creative chips only (X-Fi Xtreme Music & upwards along with the Auzentech Prelude), so it still means that Creative based cards are top of the list when it comes to gaming. Just because a cheapo software card supports OpenAL doesn't mean it'll suddenly produce all the effects EAX5 does.
Correct me if I'm wrong with the above, that's the way I see it at least.
were is the extra money going to from buying a X-Fi Xtreme Music or a Auzentech Prelude.
Is the Prelude that much better ??
