USA: We put six nukes on a plane by accident
I find it hard to tell whether the US military are really that thick or if it's mostly the media enjoying having a dig at the biggest super power. If this happened in another country would it be as big a deal?
haha dont check there sources? what about the spanish photographer making the queen go off in a tiff? that was complete nonsense. Didnt check there sources there did they? ;)
maybe not a serious, but a prime example of what the bbc will do, getting as bad as sky news or ch5 tbh
Granted that is an example but can you think of another, because I can't.
Plus the BBC revoked the story and made an apology within a couple hours.
Why is it no concern for the American Public. Do they not know anyhting of winds, dust, etc etc it will affect the globe and us if it did go bang or leak.
How would they go bang? They weren't even armed. As for leaking, that involves a very outside chance of the plane crashing in a way that dages the missiles, which in event of a problem can be jettionsoed and crash safely to Earth from quite a high altitude.
Also airspace where ever and whom ever you are is international no matter what. So they are half wrong in what they said.
It's North Dakota airspace, ergo it's inside the US and is their airspace!
Piolt must be thick or blind! How did he not see them being fitted or see they had been when he has to walk around the plane for a pre flight check.
Pre-flight walk around is done way before the weapons are attached, plus how would the pilot be able to distinguish between a nuclear tipped missile and the ones that he was probably meant to be carrying.
See this is what happens when you let yanks get carryed away!
What?
Last year in Plymouth the lost 18 tip nuke Tommahawks. They come from the munitons dump in Saltash and go to HMS DML. The wrong ones had been pulled for use. It was an american op that moved the 18 of them and again went back to get a set.
:confused::confused::confused:
Sauce please, or do you know something that wasn't reported for a reason? :rolleyes:
How could they get on the plane to begin with? How can america keep claiming more friendly kills than the rest of the world's armed forces?
if the pilot didnt know what he was carrying how could he jettison them?!!
What if that plane were to go on an excerise to test missiles, etc which they do quite frequently? It's pretty scary to think of what could have happened.
The media obviously wants people to have nuclear weapons fresh on their mind the whole time, im also not completely buying that this actually happened, and 6 nuclear weapons dont get boarded on planes and flown across the USA by accident, it dosent happen.
http://www.cnn.com/2007/US/09/05/loose.nukes/index.html
yup its a lie, cnn are in the lie with the bbc :D
Shepperd said the U.S. had agreed in a Cold War-era treaty not to fly nuclear weapons. "It appears that what happened was this treaty agreement was violated," he said
that bits the interesting bit and does this mean the treaty is invalidated...
might start seeing some of those russians at it
We are of course lacking a lot of information of this but I would suspect that an incorrect order or a misunderstood order. I would question if the ground crew would even know it's a live nuke. I expect they took the ordinance and attached it to the airframe as ordered.
As for blue on blue that is a more complex issue than the media reporting would suggest. You need to remember that the USAF is providing a huge percentage of Close Air Support and therefore would be more likely to have a blue on blue incident.
You also need to consider the lack of equipment the British Army has. They don't have IFF friend or foe equipment and very rarely have the equipment that allows them to see the targeting information from the targeting pod.
I do concede that some members of the US Air National Guard are gung-ho and are itching for some "action" but don't tar all the pilots in the USAF with the same brush. It's also very concerning that there has been a break down in protocol and communications but it wasn't that long ago that the USAF were routinely flying B-52s around the clock armed with live nuclear weapons (some of those did crash as well, including at least two weapons not being recovered!). We have come some way from then.
If you want to worry about Nuclear weapons I'd suggest you start to read the recent speeches of President Hugo Chavez.
A: "I WANT THOSE NUKES ON THAT PLANE, DOUBLE TIME!"
B: "YES SIR SARGENT MAJOR SIR"
A: "WHAT IN SAM HELL DO YOU THINK YOU WERE DOING?"
B: "SIR YOU TOLD ME TO PUT THE NUKES ON THE PLANE SIR"
A: "GODAMMIT BOY!"
Who knows. Why not.
The opinion may be held by people in military positions in countries they are soon to invade (Seria/Iran) which gives them an advantage to a point.
Maybe there's a deeper ulterior motive. It's not a bad thing to question what you are told. Human nature > Blind Acceptance
t.
Of course they do! Maybe not all, but yes some do
